Hello, do the Uno and Duemilanove have the same mounting hole positions? I still have an old Duemilanove laying around and I would like to mount it on a plate that was designed for the Uno. However, if the mounting holes are not in the same position, there is no point in buying this plate. Please let me know. Thanks!
Is there a similar drawing for the Uno so I can compare?
lotte1990:
Yeah Arduino UNO & Arduino Duemilanove have almost the same mounting hole positions. They have a slight difference, in UNO there are 4 mounting holes and Duemilanove has 3 mounting holes and they are exactly at the same position as in UNO. Its just the 4th hole is missing in Duemilanove, which is the top left one near capacitors.
So, in your case, I think this plate will work for you.
