Mouse Button controller going to bottom of screen
Okay so I am making a gaming controller out of an arduino esplora.
I needed a second joystick other than the onboard joystick, but could not obtain one, so I used a five position switch the code is fairly self explained.
When i plug the arduino in the mouse cursor just goes to the bottom right corner of the screen and the buttons on the switch do not work, How can I fix this?
#include <Esplora.h>
#include <Mouse.h>
#include <Keyboard.h>
 const int upButton = 11;       // do I really need to take notes on this one for myself
 const int downButton = 9;     // Dude if I cant understand this it's hopeless
 const int leftButton = 10;   //
 const int rightButton = 1; //
 const int mouseButton = 28;
 int range = 5;
 int responseDelay = 10;
boolean buttonStates[8];
const byte buttons[8] = {
JOYSTICK_DOWN,
JOYSTICK_LEFT,
JOYSTICK_UP,
JOYSTICK_RIGHT,
SWITCH_RIGHT,
SWITCH_LEFT,
SWITCH_UP,
SWITCH_DOWN,
const char keystrokes[8] = {
'S',
'A',
'W',
'D',
'Q',
't',
'E',
'v'
//You can change the keys to whatever you want.
  Mouse.begin();              // take control of the mouse
  Keyboard.begin();          // takes control of keyboard
  pinMode(upButton, INPUT);        // tells arduino that this constant is input
  pinMode(downButton, INPUT);     // tells arduino that this constant is input
  pinMode(leftButton, INPUT);    // tells arduino that this constant is input
  pinMode(rightButton, INPUT);  // tells arduino that this constant is input
  pinMode(mouseButton, INPUT); // tells arduino that this constant is input
void loop(){{
  int upState = digitalRead(upButton);
  int downState = digitalRead(downButton);
  int rightState = digitalRead(rightButton);
  int leftState = digitalRead(leftButton);
  int clickState = digitalRead(mouseButton);
  if(digitalRead(upState) == HIGH){
    Mouse.move(0, 100, 0);
    if(digitalRead(downState) == HIGH){
    Mouse.move(0, -100, 0);
    }if(digitalRead(leftState) == HIGH){
    Mouse.move(-100, 0, 0);
    if(digitalRead(rightState) == HIGH){
    if(digitalRead(clickState) == HIGH){
    Mouse.click();
    int valueSlider = Esplora.readSlider();
    if(digitalRead(valueSlider) > 800){
      Keyboard.press('r');
//BELOW THIS LINE IS AKASH'S STUFF DO NOT TWEAK
for(byte thisButton = 0; thisButton < 8; thisButton++) {
boolean lastState = buttonStates[thisButton];
boolean newState = Esplora.readButton(buttons[thisButton]);
if (lastState != newState) {
if (newState == PRESSED) {
Keyboard.press(keystrokes[thisButton]);
else if (newState == RELEASED) {
Keyboard.release(keystrokes[thisButton]);
buttonStates[thisButton] = newState;
delay(50);
int yAxis = Esplora.readAccelerometer(Y_AXIS);
if (yAxis > -15)
{ Keyboard.press(KEY_LEFT_CTRL);
Keyboard.release(KEY_LEFT_CTRL);
delay(50);
  if (yAxis < 15) {
Keyboard.write((char) 32);
delay(50);
delay(50);
I guess you ARE hopeless, then, since you left the stupid comments in.
Connected to which 5 pins? With external resistors? Since you are not using the internal pullup resistors, you MUST have external resistors. Since you are expecting HIGH to mean pressed, they must be wired in a pull-down configuration.
These button pins are very interesting to put it mildly:
const int upButton = 11;    // leftmost Tinkerkit connector (labeled OUT2)
const int downButton = 9;   // blue on the RGB LED
const int leftButton = 10;  // green on the RGB LED
const int rightButton = 1;  // on the LCD connector (LCD reset)
const int mouseButton = 28; // a.k.a. A10 which also happens to be digital pin 10
An extra digitalRead():
    int upState = digitalRead(upButton);    //// value is 0 or 1
    if (digitalRead(upState) == HIGH) {     //// reads pin 0 or 1
I meant the other left:
(how the heck does this go to bottom right?)
    } if (digitalRead(leftState) == HIGH) {
    if (digitalRead(rightState) == HIGH) {
Pin 10 and pin 28 are quite separate pins. A10 is NOT the name assigned to digital pin 10. It is the name assigned to analog pin 10's use as a digital pin.
Pins 10 and 28 (A10) are the same pin on Leonardo/Micro/Esplora/other 32u4 boards.
Take a look at variants/leonardo/pins_arduino.h and pay attention especially to these:
#define PIN_A10  (28)
// D10#     A10     PB6     PWM16       OC1B/0c4B/ADC13/PCINT6
const uint8_t PROGMEM digital_pin_to_port_PGM[] = {
    PB, // D10 - PB6
    PB, // D28 / D10 - A10 - PB6
const uint8_t PROGMEM digital_pin_to_bit_mask_PGM[] = {
    _BV(6), // D10 - PB6
    _BV(6), // D28 / D10 - A10 - PB6
const uint8_t PROGMEM analog_pin_to_channel_PGM[] = {
    13, // A10      D10     PB6                 ADC13
