Hi Arduino community,
I just started programming with arduino this week with my arduino pro micro, and to test it out, I uploaded a script that goes like this:
void setup() {#include "Mouse.h"
Mouse.begin();
if (10 == 10) {
Mouse.click();
The problem is, my mouse keeps on clicking, so I can't upload another piece of code onto the board, because I have to change the port before I can upload it. All of this means that I basically cannot use my board anymore. Does anyone know what to do to get out of this situation? Thanks so much!
Select the appropriate board from the Tools > Board menu.
Hold down the reset button on your Arduino board. If you have a Pro Micro, there is no reset button, so you’ll need to use a wire to connect the GND and RST pins.
Plug your Arduino board’s USB cable into your computer.
Sketch > Upload
Watch the black console window at the bottom of the Arduino IDE window. When you see something like this:
Sketch uses 3462 bytes (12%) of program storage space. Maximum is 28672 bytes.
Global variables use 149 bytes (5%) of dynamic memory, leaving 2411 bytes for local variables. Maximum is 2560 bytes.
release the reset button (or disconnect the wire between the RST and GND pins on the Pro Micro).
