johnwasser:
The "usb.Task()" function is a feature of the USBhost library that only works on an Arduino DUE.
USBHost - Arduino Reference
If you want to connect a USB mouse to an Arduino Leonardo I think you need to add a "USB Host Shield" and the library for it.
Thanks for your answer johnwasser.
I achieved what I was trying to do.
I'm trying to slow the speed of Y while dragging the mouse down.
Using the GitHub - felis/USB_Host_Shield_2.0: Revision 2.0 of USB Host Library for Arduino. library, I can have the events, etc.
The snippet I have for it:
void MouseRptParser::OnMouseMove(MOUSEINFO *mi)
Serial.print("dx=");
Serial.print(mi->dX, DEC);
Serial.print(" dy=");
Serial.println(mi->dZ);
if (pressed)
if (mi->dZ > 0)
mi->dZ = 1;
Using conventional mice, I can hold the speed while dragging but I have Zowie mouse configured for 400 dpi. Still, the sensitivity of this mouse is so low, which means if I set the velocity 1 is not enough to decrease for the desired speed while dragging.
You can see I set dZ because I had to change the library; the Y is configured under a different buffer position.
void MouseRptParser::Parse(USBHID *hid, bool is_rpt_id, uint8_t len, uint8_t *buf)
MouseReportParser::Parse(hid, is_rpt_id, len, buf);
if (len > 2) {
uint8_t mouseRpt[4];
mouseRpt[0] = buf[0];
mouseRpt[1] = buf[1];
mouseRpt[2] = buf[3];
if (len > 3) {
mouseRpt[3] = buf[5];
else {
mouseRpt[3] = 0;
Serial.print(buf[0]);
Serial.print("\t");
Serial.print(buf[1]);
Serial.print("\t");
Serial.print(buf[2]);
Serial.print("\t");
Serial.print(buf[3]);
Serial.print("\t");
Serial.print(buf[4]);
Serial.print("\t");
Serial.print(buf[5]);
Serial.print("\t");
Serial.print(buf[6]);
Serial.print("\t");
Serial.print(buf[7]);
Serial.print("\t");
Serial.print(buf[11]);
Serial.print("\t");
Serial.print(buf[12]);
Serial.print("\t");
Serial.print(buf[13]);
HID().SendReport(1, mouseRpt, sizeof(mouseRpt));
The result:
But the Y expects an int, and as mentioned 1 is too high for 400 dpi, I was wondering some double conversion to have 1 split in half, but the library doesn't accept that.
The question is, while the native uses this buffer index to represent Y, is it possible to find out where is the secondary index position in the buffer, which represents the decimal for the velocity?
Thanks,
Bruno Arruda
