when i try calling a subroutine with Mouse.move(2,0,0) followed by Mouse.move(0,2,0), the mouse moves along the x axis only.
code:
mouseHome():
void mouseHome(){
for(int i; i > -2000; i -= 120){
Mouse.move(-120, -120, 0);
this works:
void mouseGoToIcon(){
mouseHome();
mouseGoToIconX();
mouseGoToIconY();
void mouseGoToIconX(){
for(int x; x < 350; x += 2){
Mouse.move(2, 0, 0);
void mouseGoToIconY(){
for(int y; y < 200; y += 2){
Mouse.move(0, 2, 0);
and this doesn't work (mouse only moves in x direction):
mouseHome();
and each time i'm calling mouseGoToIcon(). i'm not sure what the issue is. the code is working right now, it just takes a few extra lines is all. any insight would be appreciated.
You're initializing i with a random value. It may be 0, it may not be. Don't assume it is. Also, if you're not using i anywhere in your block of code below the for statement, then why both defining some crazy stop and increment parameters? Assuming i has an initial value of zero, the function will run 17 times, so why not simplify it to:
for (int i=0; i<17; i++)
Since there is no delay, why bother sending 17 different commands? Why not simplify it it a single command?
Arrch:
good point, thanks.
Mouse.move(-2040, -2040, 0);
What is the point of the for loops?
because Mouse.move() uses a signed char, so anything over 126 or below -126 doesn't work.
thanks for the post, it helps to have another set of eyes on the code
