Mouse Press help
Hi, this is my very first post here as I am new to the community so hello everybody, also I am new to programming and can't wrap my head around the problem that I am heaving.
My setup: I have PS2 mouse sensor attached to Arduino Leonardo and switch, Arduino, is hooked to a PC using USB port and I want to read mouse sensor data and send it to PC.
When mouse is active (I am using switch button to activate mouse ) that part of project is working I am getting x and y coordinates and sending them to pc and moving cursor, now I want to add peace of code that sense, when x and y data are different from 0 and press left mouse click and when they are 0 to release left mouse click, this part is working also but not the way I want, it to send ton of mouse clicks and releases I just want to press it and hold it while x and y are !=0 and to release it when x, y = 0 so if anybody has an idea how to achieve this or can guide me full code is below.
Thanks.
USB Pinout (Left to Right, USB symbol up)
4: GND
3: Clk
2: Data
1: Vcc
#include "PS2Mouse.h"
#include <Mouse.h>
const int switchPin = 2;      // switch to turn on and off mouse control
const int ledPin = LED_BUILTIN; // Mouse control LED
// parameters for reading the mouse:
int range = 12; // output range of X or Y movement
int responseDelay = 5; // response delay of the mouse, in ms
int threshold = range / 4; // resting threshold
int center = range / 2;          // resting position value
boolean mouseIsActive = false;     // whether or not to control the mouser
int lastSwitchState = LOW;        // previous switch state
PS2Mouse mouse(6,5);
void setup(){
while(!Serial);
Serial.print("Setup...");
mouse.begin();
Serial.println("complete!");
 // initialize digital pin LED_BUILTIN as an output.
 pinMode(switchPin, INPUT);       // the switch pin
 pinMode(ledPin, OUTPUT);         // the LED
// take control of the mouse:
Mouse.begin();
delay(5000);
void loop(){
  // read the switch:
  int switchState = digitalRead(switchPin);
  // if it's changed and it's high, toggle the mouse state:
  if (switchState != lastSwitchState) {
    if (switchState == HIGH) {
      mouseIsActive = !mouseIsActive;
      // turn on LED to indicate mouse state:
      digitalWrite(ledPin, mouseIsActive);
  // save switch state for next comparison:
  lastSwitchState = switchState;
  uint8_t stat;
  int x,y;
  mouse.getPosition(stat,x,y);
  // read and scale the two axes:
int xReading = x;
int yReading = -y;
 // if the mouse control state is active, move the mouse:
  if (mouseIsActive) {
  Mouse.move(xReading, yReading, 0);
  Serial.println("ON");
  if (xReading + yReading != 0) {
      Mouse.press();
      Serial.println("click");
    else{
      Mouse.release();
      Serial.println("click release");
  else{
  Serial.println("OFF");
  Serial.print("\tx=");
  Serial.print(x);
  Serial.print("\ty=");
  Serial.println(y, DEC);
  //delay(1000);
reads an axis (0 or 1 for x or y) and scales the
analog input range to a range from 0 to <range>
int readAxis(int thisAxis) {
// read the analog input:
int reading = analogRead(thisAxis);
// map the reading from the analog input range to the output range:
reading = map(reading, 0, 1023, 0, range);
// if the output reading is outside from the
// rest position threshold, use it:
int distance = reading - center;
if (abs(distance) < threshold) {
distance = 0;
  // return the distance for this axis:
return distance;
Look at File->Examples->02.Digital->StateChangeDetection for an example of doing something only when something CHANGES. In your case you want to do something once when x and y change from "both zero" to "not both zero" and a different thing when x and y change from "not both zero" to "both zero".
