Mouseless...
found a link http://www.pranavmistry.com/projects/mouseless/ i wanted to implement something similar with an ir array SUGGESTIONS ! please :)
i wanted to use an arduino and affix a ir led array to the right side of the key board to detect the place of a finger
i remember this project by Grumpy_mike http://www.thebox.myzen.co.uk/Hardware/The_Sound_Square.htmlbut i dont want sensors on both sides i just want them on one side of the key-board This is my idea have the no of sensor blocked to knoe the vertical position and distance reading ( analog value ) to detect the horizontal position
You will discover why they rejected that method.
:-? :-? ? WHY SO
ok what about the distance measuring ir part ? if i filter the ir, i mean assuming very little noise ? what are the chances ? any way for this project what can be a tolerable error ?
this is my idea
well i drew that image in paint and i dont understand how to make it apppear bigger use the zoom in the browser ;)
3) It provides no Z-axis measurement at all.
i m ay sound stupid but why do i require Z Axis ? the screen is two dimensional and i am using a two dimensoinal plane i never wanted to do anything in the air
yeah But for the moment i am rather intrested in tracking the movement of the hand in the given 2-D plane then ill think of the mouse click for now i just want to move the pointer ::) ( though it dosent make sense Just want to try it out ;) )
In that case, go for it.
but maybe you will get lucky.
hope so ;)
DOin the same ;)
anyways any idea for a code to make a mouse move with a array from arduino ? :)
2) You are asking about step #13 when you haven't even started step #1. If you get to the point where you can get a good resolution position from your experiment, then we will help you translate that into mouse movement.
Sorry might be o was a bit over exited ;) :-X until i am done with building the thingy ::)
