Move faster a 12V DC motor with L298N
Hi everyone, I need help fast.
I have to put a DC 12V motor with Arduino Nano (Old Bootloader), an H bridge L298N and an IR receiver to change the speed with a control, but it is very slow connected to a gear, how do I make the motor go faster?
Here's the code just in case.
//Receptor IR S = D3
//L298N 9=1 white 8=2 brown 10=ENA red
#include<IRremote.h>
int SENSOR = 3;
int enA=10;
int in1=9;
int in2=8;
IRrecv irrecv(SENSOR);
decode_results results;
  pinMode (enA, OUTPUT);
  pinMode (in1, OUTPUT);
  pinMode (in2, OUTPUT);
  digitalWrite(in1, LOW);
  digitalWrite(in2, HIGH);
  irrecv.enableIRIn();
void speed3()
    digitalWrite(enA, HIGH);
void speed2()
    analogWrite(enA,170);
void speed1()
    analogWrite(enA,85);
  if (irrecv.decode(&results)) {
    Serial.println(results.value, HEX);
    irrecv.resume();
  if(results.value == 0xC9767F76)
   speed1 ();
  if(results.value == 0xC8155AB1)
   speed2 ();
  if(results.value == 0xB6996DAE)
   speed3 ();
  if(results.value == 0xF32F72D7)
   analogWrite (enA,0);
Use a modern motor driver. The ancient L298 dinosaur wastes about 1/3 of the battery voltage as heat, and it may even be overheating and shutting down.
Pololu has the best selection of modern motor drivers, for example, this one.
Pick a motor driver that can easily handle the start/stall current of your motor.
Hi, @saintsyt
Does your motor speed run fast enough when connected directly to the motors power supply?
What is your motor power supply?
Thanks.. Tom... :grinning: :+1: :coffee: :australia:
thanks, but i can´t
but i solved this
Can't what?
Tom.. :grinning: :+1: :coffee: :australia:
ok thanks
How, please let us know your solution.
@saintsyt ,
I have closed your other topic on the same subject. Please do not create more than one topic on the same subject because it wastes the time of the volunteers trying to help you. If you continue to do so you risk a ban from the forum.
Thank you.
