Move servo after pressing X times a button, then back after pressing X times
Hello all, I am trying to move a servo 90deg after a button is pressed 9 times, then move back to 0deg after another 9 presses. The code i am trying to use is here, 10 presses = 0 so the count will restart on its own ( i will change that to 10=1 so it is accurate count and not adding the 0. I am trying to insert the servo code ( which I don't have) between 9 and 10 but i don't know how to. Thank You
int f = 13;
int g = 12;
int e = 11;
int d = 10;
int c = 9;
int b = 8;
int a = 7;  //7 Segment pin
int buttonPin = 5;  //the number of the pushbutton pin
int buttonState = 0;         // variable for reading the pushbutton status
int p=0;    // variable
  pinMode(f, OUTPUT);
  pinMode(g, OUTPUT);
  pinMode(e, OUTPUT);
  pinMode(d, OUTPUT);
  pinMode(c, OUTPUT);
  pinMode(b, OUTPUT);
  pinMode(a, OUTPUT);
  pinMode(buttonPin, INPUT);
   buttonState = digitalRead(buttonPin);
   if (buttonState == HIGH)
      p++;
 if(p==0)
 digitalWrite(a,1);
 digitalWrite(b,1);
 digitalWrite(c,1);
 digitalWrite(d,1);
 digitalWrite(e,1);
 digitalWrite(f,1);
 digitalWrite(g,0);   // 0
  if(p==1)
 digitalWrite(a,0);
 digitalWrite(b,1);
 digitalWrite(c,1);
 digitalWrite(d,0);
 digitalWrite(e,0);
 digitalWrite(f,0);
 digitalWrite(g,0);   // 1
  if(p==2)
 digitalWrite(a,1);
 digitalWrite(b,1);
 digitalWrite(c,0);
 digitalWrite(d,1);
 digitalWrite(e,1);
 digitalWrite(f,0);
 digitalWrite(g,1);   // 2
  if(p==3)
 digitalWrite(a,1);
 digitalWrite(b,1);
 digitalWrite(c,1);
 digitalWrite(d,1);
 digitalWrite(e,0);
 digitalWrite(f,0);
 digitalWrite(g,1);   // 3
  if(p==4)
  digitalWrite(a,0);
 digitalWrite(b,1);
 digitalWrite(c,1);
 digitalWrite(d,0);
 digitalWrite(e,0);
 digitalWrite(f,1);
 digitalWrite(g,1);   // 4
 if(p==5)
 digitalWrite(a,1);
 digitalWrite(b,0);
 digitalWrite(c,1);
 digitalWrite(d,1);
 digitalWrite(e,0);
 digitalWrite(f,1);
 digitalWrite(g,1);   // 5
   if(p==6)
   digitalWrite(a,0);
 digitalWrite(b,0);
 digitalWrite(c,1);
 digitalWrite(d,1);
 digitalWrite(e,1);
 digitalWrite(f,1);
 digitalWrite(g,1);   // 6
  if(p==7)
  digitalWrite(a,1);
 digitalWrite(b,1);
 digitalWrite(c,1);
 digitalWrite(d,0);
 digitalWrite(e,0);
 digitalWrite(f,0);
 digitalWrite(g,0);   // 7
  if(p==8)
 digitalWrite(a,1);
 digitalWrite(b,1);
 digitalWrite(c,1);
 digitalWrite(d,1);
 digitalWrite(e,1);
 digitalWrite(f,1);
 digitalWrite(g,1);   // 8
  if(p==9)
  digitalWrite(a,1);
 digitalWrite(b,1);
 digitalWrite(c,1);
 digitalWrite(d,0);
 digitalWrite(e,0);
 digitalWrite(f,1);
 digitalWrite(g,1);   // 9
if(p==10)
  p=0;
Something like this maybe ...
if (buttonCount == 9) {
  if (servoPos == 0) {
      servoPos = 90;
  else {
     servoPos = 0;
  myServo.write(servoPos);
Note that some servos don't move as far as 0 so you may need to adjust the numbers
...R
PS ... thank you for using the code button. You should also use the AutoFormat tool to indent your code consistently. It will make it much easier to see which parts belong together.
Thank you,
I see about the 0 position I may use 90-180 or any other 2 numbers,
Once i get the rig going i will give feedback.
I see how the code works as a flowchart
Now i just have to get to know how to create those flowcharts and commands
thank you again
