Hi all,
I have two servos that i plant to implement on a prototype excavator. one servo will move the arm up and down and the other will move the bucket to and fro. I want the bucket and arm to be at a particular position. I am using one joystick, when i move t he joystick up it will control one motor and i will like that when i press the onboard joystick button that i can move the joystick same up and down to control the other motor without moving the other motor. I am not sure what pin on the arduino to attach the onboard select button. Below is my code, it doesnt allow the select button to do anything, i.e the two servos move simultaneously when i move the joystick
int Joy_button = 2; // button from joystick input
//const int Push_button_1 = 3;
//const int Push_button_2 = 4;
const int led = 13; // onboard led
int x = 512; // set initial value for x
int y = 512; // set initial value for y
int z = 0; // set initial value for z
#include <Servo.h> // include servo library
Servo first_servo, second_servo; // create server object to control the first servo
first_servo.attach(3); // attach the servo on pin 9
second_servo.attach(4);
//Joy_button.attach(2) ;
void loop(){
digitalRead(Joy_button);
if (Joy_button,1) {
x = analogRead(A0); // read the value from the joystick 0-1023
x = map(x,0,1023,0,180); //scale the analog input values form the pot to a suitable digital signal
first_servo.write(x); // sets the servo position
delay(15); // waits
else if (Joy_button,0);
second_servo.write(x); // sets the servo position
delay(15);
Why not? You defined a variable, Joy_button, assigned it a value, and provided a comment that implies that is where the joystick button is (to be) attached.
Useless names. How are we supposed to know which servo does what? Suppose, instead, that you had used names like bucketServo and armServo. Then, we could assume that bucketServo moved the arm, and that armServo moved the bucket. Or that other way around.
But throw the result away. Why?
if (Joy_button,1) {
You are going to have to explain this misuse of the comma operator. What are you trying to do here?
and here. And explain why there is a semicolon on the end.
In any case, Joy_button is always 2, so (syntax aside) doing an "if" on it is meaningless. You mean to look at the value of the pin as read, I think, but as PaulS just said, you threw that away.
@ PaulS , thanks for the pointers man . Ill fix it . @Robin2 , I checked that out before i posted this, didnt really help me . thanks for your input though bro/sis lol
You might try making the servo commands a variable that is sent to the servo in the main loop. Make an if statement in the main loop that updates the servo command variable if the button is pushed. The variable update is skipped when the button is not pressed.
@Robin2 Sorry i am new to posting in forums. this is my second day at posting in forums in my life !
More importantly bro, i saw your post from this thread Re: Controls for a project - #40 by system - Project Guidance - Arduino Forum on how to control the servos the way i wanted. thanks for that. Also I was wondering if there was a way to be able to push a button and have the motors go to a particular position.... lets say 90 degrees or the orginal position. below is what i tried <note that the push button i placed is connected to dig pin 2> In my code that is derived from yours I try to set the potValue to 512 so that it can make that 90 degree angle.
#include <Servo.h>
#define mainArm 0
#define jib 1
#define bucket 2
#define slew 3
Servo servo[4]; //code used for attaching upto 4 servos
byte angle[4] = {90, 90, 90, 90}; // middle point for servo angle
byte potPin[4] = {A0, A1, A2, A3}; // input pins to attach your potentiometers
byte servoPin[4] = {7, 6, 10, 9}; // input pins to attach servos
const int buttonPin = 2 ; // push-button attached to 2
int buttonState = 0 ; // State of the push-button
int potVal ;
Serial.println("Starting DiggerCode.ino");
pinMode(buttonPin, INPUT) ; // set push button as an input
for (byte n = 0; n < 4; n++) {
servo[n].attach(servoPin[n]);
readPotentiometers();
moveServos();
delay(10);
buttonState = digitalRead(buttonPin);
if(buttonState == HIGH);
potVal == 512;}
void readPotentiometers() {
int potVal;
potVal = analogRead(potPin[n]);
if (potVal < 200) { // dead zone for the joystick I used is 200 to 550.
angle[n] += 1;
if (angle[n] > 170) {
angle[n] = 170;
if (potVal > 550) { // deadzone upper value
angle[n] -= 1;
if (angle[n] < 10) {
angle[n] = 10;
void moveServos() {
servo[n].write(angle[n]);
