Are you allowed to attach anything to said eyelid?
You need to give a lot more detail about your 'noble application' if you actually want help.
Otherwise you'll be getting a lot of different suggestions and you'll just spend your time being a pain in the ass by saying 'no that won't work' when it's because you failed to give detail.
INTP:
Yes, allowed. You are right, my project is about a ocular reader for disable people. It is important that is cheap and open source, accuracy is not important at moment.
TomGeorge:
Do you need know if they are up or down?
Check to see if you get a change in IR radiation from the eye and eyelid.
What is the application?
Tom..
I need only to take the movement. Check the change of IR radiations are my principal goal for the moment
