Movie camera trap - bluetooth issues
I am making a system for a freind to help him filming wildlife. At the moment I have an Infra red beam system which triggers the camera when a beam is broken. I want to expand the system using other sensors.
The filming sequence may be started by the IR beam sensor but then the filming period could be extended if movent was detected by another sensor. This other sensor could be another IR beam sensor or perhaps a PIR sensor or a pressure mat or whatever.
I am looking for a radio system to link these different sensors together. They probably wont be very far apart but I think the radio link will be better than using a hard wire link.
I have been experimenting with HC-05 bluetooth modules. I read that these modules draw about 5mA when idle, this I feel is tolerable for my battery powered gadgets. But right now I have 2 modules, one configured as master and one as slave, in front of me and the slave is drawing 19mA, the master is drawing the expected 5mA. Both appear to be linked, doing there slow flashing and no data is being sent either way, in fact they only have power connections, no data connections at all. I have reconfigured both modules so that the master is now the slave and vice versa but the slave alwys draws the higer current.
Can anyone explain this and tell me how to get the lower current draw that I need for this project.
Thanks in anticipation
I have no experience with these. You have a problem for the receiver to sense and or receive data it needs to be active. Try powering it down then wake up for a short time to sniff for a signal. This will not drop the current consumption but it will drop your average current consumption.
