Moving average in speed measurement
const int encoderPinA = 2;
//const int encoderPinB = 3;
volatile unsigned long pulseDuration; //to store the pulse duration, volatile because can change abruptly
const int interval = 1000;
volatile unsigned long lastTime = 0;
const int PPR = 240; //ppr is 12 and gear ratio 20:1 so eff ppr =12*20
const int numReadings = 5;
int readings[numReadings];// array to store the readdings
int readIndex = 0;
int total = 0;
int average = 0;
  pinMode(encoderPinA,INPUT);
   for (int thisReading = 0; thisReading < numReadings; thisReading++) {
    readings[thisReading] = 0; // Initialize the readings array to zero
  //pinMode(encoderPinB,INPUT);
  attachInterrupt(digitalPinToInterrupt(encoderPinA), encoderISR, FALLING);
  lastTime = micros();
void loop(){
  //lastTime = micros();
  // noInterrupts();
   //lastTime = 0;
   total = total - readings[readIndex];// subtracting the last reading from the total
   readings[readIndex] = pulseDuration;
    total = total + readings[readIndex];
    readIndex = readIndex + 1; // readIndex is position so move on to next position,
    if (readIndex >= numReadings) {
    readIndex = 0;
  average = total / numReadings;
  // Serial.print("pulseduration: ");
    //Serial.print(pulseDuration);
    //Serial.println("microseconds");
    //noInterrupts();
//unsigned long duration = pulseDuration ;
Serial.print("averagepulseduration:");
Serial.print(average);
interrupts();
float speed = (60.0*1000000.0)/(average*(float)PPR);
//interrupts();
Serial.print("speed:");
Serial.print(speed);
Serial.println("RPM");
//interrupts();
//delay(interval);
void encoderISR(){
  unsigned long currentTime = micros();
  pulseDuration = currentTime - lastTime;
  lastTime = currentTime;
I have wrote this code to measure the rpm of a encoded dc motor by measuring the pulseduration between two consecutive pulses. Is this the correct way to calculate average pulseduration.
I would make these and your array unsigned long
No, because it fills the array with pulse durations without waiting for a new pulse to be measured. So you will probably get 20 copies of the same pulse duration in the array.
PS. You are not measuring, and don't want to measure, the pulse durations. You are measuring the pulse period, the time between rising or falling edges of consecutive pulses.
ok i'll try that
what should I do to fix the array.
I see its pulse period what it is.
You should update the array only when a new pulse period has been measured.
pulseDuration (which should be called pulsePeriod) is zero when the code begins to run. After the first period has been measured, it will be greater than zero. In loop() you can test for this, and update the array only when the new reading is not zero. You can also set pulseDuration back to zero after reading it so that loop() will know when the next reading has been taken.
When reading or updating a volatile variable in loop() you should disable interrupts, otherwise the reading can get corrupted. Interrupts should be enabled again as quickly as possible, otherwise interrupts could be missed.
 noInterrupts();
    readIndex = 0;
    interrupts();
will it work?
No.
Are you able to understand the advice I am giving you? Have you tried using Google Translate?
You haven't said what kind on encoder you have but you probably need:
pinMode(encoderPinA,INPUT_PULLUP);
This will do what you want
// Computes the average of the last 5 pulse durations.
//variable to store the pulse duration, volatile because it's used in an ISR
volatile bool newPulse = false;
unsigned long readings[numReadings] = {0, 0, 0, 0, 0}; // array to store the readings
int readIndex = 0;
  pinMode(encoderPinA, INPUT);
  //pinMode(8, OUTPUT); // for DEBUGGING
  unsigned long total, average;
  int i;
  //tone (8, 200); // for DEBUGGING
  // Check if a new pulseDuration is available
  if (newPulse)
    readings[readIndex] = pulseDuration; // put in array
    if (readIndex == numReadings) readIndex = 0;
    newPulse = false;
  // Compute the average of the last numReadings
  total = 0;
  for (i = 0; i < numReadings; i++)
    total = total + readings[i];
  Serial.print("averagepulseduration:  ");
  Serial.println("  ms");
  float speed = (60.0 * 1000000.0) / (average * (float)PPR);
  Serial.print("speed: ");
  Serial.println(" RPM");
void encoderISR() {
  newPulse = true;
thanks a lot . I appreciate your help.
Have fun!
