Moving Average
Hi, I’m Gokul… i’m working on an open energy meter… here the outputs are voltage, current and powerfactor where i’m getting high amount of samples per second…
So i thought of taking moving average for 60 seconds and displays as one minute sample… but the problem is the number of samples keep varying… I have attached the energy meter code with this post… can any one help me with this…
Thanks in advance… :slight_smile:
New Text Document.txt (18.8 KB)
When you find yourself adding numeric suffixes to variable names, it's time to start reading about arrays.
long readVcc() {
/*ADMUX = _BV(REFS0) | _BV(MUX4) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1); // for ADK
  ADMUX = _BV(REFS0) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);  //for UNO
  delay(2); // Wait for Vref to settle
  ADCSRA |= _BV(ADSC); // Start conversion
  while (bit_is_set(ADCSRA,ADSC)); // measuring
  uint8_t low  = ADCL; // must read ADCL first - it then locks ADCH
  uint8_t high = ADCH; // unlocks both
  long result = (high<<8) | low;
  result = 1125300L / result; // Calculate Vcc (in mV); 1125300 = 1.1*1023*1000
  return result; // Vcc in millivolts */
  long result;
  // Read 1.1V reference against AVcc
  ADCSRA |= _BV(ADSC); // Convert
  result = ADCL;
  result |= ADCH<<8;
  result = 1126400L / result; // Back-calculate AVcc in mV
  return result;
What do you imagine a “return” statement does?
Why does this function have two?
Actually… this energy meter code is written for UNO as well as ADK… so the adk mux are commented…!
Gokulshriyam: Actually.. this energy meter code is written for UNO as well as ADK... so the adk mux are commented...!
And that answers my question . . . how?
Edit: Oh - you hid the comments.
If you want to ignore a block of code, #ifdef/#if...#endif is much simpler and more visible.
. . . and now you're cross-posting.
I just lost interest in your problem.
Cross-post deleted.
This below code works with Mega Adk… I have deleted all the uno codes …
long readVcc() {
result = 1125300L / result; // Calculate Vcc (in mV); 1125300 = 1.110231000
