Moving Balance Bot Left, Right, Back and Forth
Hi there,
I'm trying to add to my code to where my bot will move back an forth left and right in a square-like motion so 90 degrees. It could also be 180 degree turn and just go back and forth a straight line, but not sure how to add it to the existing code. It's also set to go back and forth, but I'm wanting for it to keep moving for X amount of seconds or so.
I'm using Arduino, DRV8833, MPU6050, I will add distance sensor, and 2 6V pololu motors with encoders. For power it's a 6V NimH battery.
Any help would be appreciate it. Thanks
#include <PID_v1.h>
#include <LMotorController.h>
#include "I2Cdev.h"
#include "MPU6050_6Axis_MotionApps20.h"
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
    #include "Wire.h"
#endif
#define LOG_INPUT 0
#define MANUAL_TUNING 1
#define LOG_PID_CONSTANTS 0 //MANUAL_TUNING must be 1
#define MOVE_BACK_FORTH 1
#define MIN_ABS_SPEED 30 //20
//MPU
MPU6050 mpu;
// MPU control/status vars
bool dmpReady = false;  // set true if DMP init was successful
uint8_t mpuIntStatus;   // holds actual interrupt status byte from MPU
uint8_t devStatus;      // return status after each device operation (0 = success, !0 = error)
uint16_t packetSize;    // expected DMP packet size (default is 42 bytes)
uint16_t fifoCount;     // count of all bytes currently in FIFO
uint8_t fifoBuffer[64]; // FIFO storage buffer
// orientation/motion vars
Quaternion q;           // [w, x, y, z]         quaternion container
VectorFloat gravity;    // [x, y, z]            gravity vector
float ypr[3];           // [yaw, pitch, roll]   yaw/pitch/roll container and gravity vector
//PID
#if MANUAL_TUNING
  double kp , ki, kd;
  double prevKp, prevKi, prevKd;
#endif
double originalSetpoint = 179;
double setpoint = originalSetpoint;
double movingAngleOffset = .3;
double input, output;
int moveState=0; //0 = balance; 1 = back; 2 = forth
#if MANUAL_TUNING
  PID pid(&input, &output, &setpoint, 0, 0, 0, DIRECT);
#else
  PID pid(&input, &output, &setpoint, 70, 240, 1.9, DIRECT);
#endif
//MOTOR CONTROLLER
//Potentiometer Side
int ENA = 10;
int IN1 = 12;
int IN2 = 9;
//MPU Side
int IN3 = 6;
int IN4 = 7;
int ENB = 8;
LMotorController motorController(ENA, IN1, IN2, ENB, IN3, IN4, 1, 1);
//timers
long time1Hz = 0;
long time5Hz = 0;
volatile bool mpuInterrupt = false;     // indicates whether MPU interrupt pin has gone high
void dmpDataReady()
    mpuInterrupt = true;
    // join I2C bus (I2Cdev library doesn't do this automatically)
        Wire.begin();
        TWBR = 24; // 400kHz I2C clock (200kHz if CPU is 8MHz)
    #elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
        Fastwire::setup(400, true);
    #endif
    // initialize serial communication
    // (115200 chosen because it is required for Teapot Demo output, but it's
    // really up to you depending on your project)
    while (!Serial); // wait for Leonardo enumeration, others continue immediately
    // initialize device
    Serial.println(F("Initializing I2C devices..."));
    mpu.initialize();
    // verify connection
    Serial.println(F("Testing device connections..."));
    Serial.println(mpu.testConnection() ? F("MPU6050 connection successful") : F("MPU6050 connection failed"));
    // load and configure the DMP
    Serial.println(F("Initializing DMP..."));
    devStatus = mpu.dmpInitialize();
    // supply your own gyro offsets here, scaled for min sensitivity
    mpu.setXGyroOffset(39);                                   // Set from setup application
    mpu.setYGyroOffset(-11);
    mpu.setZGyroOffset(45);
    mpu.setXAccelOffset(1600);
    mpu.setYAccelOffset(-1165);
    mpu.setZAccelOffset(1403);
    // make sure it worked (returns 0 if so)
    if (devStatus == 0)
        // turn on the DMP, now that it's ready
        Serial.println(F("Enabling DMP..."));
        mpu.setDMPEnabled(true);
        // enable Arduino interrupt detection
        Serial.println(F("Enabling interrupt detection (Arduino external interrupt 0)..."));
        attachInterrupt(0, dmpDataReady, RISING);
        mpuIntStatus = mpu.getIntStatus();
        // set our DMP Ready flag so the main loop() function knows it's okay to use it
        Serial.println(F("DMP ready! Waiting for first interrupt..."));
        dmpReady = true;
        // get expected DMP packet size for later comparison
        packetSize = mpu.dmpGetFIFOPacketSize();
        //setup PID
        pid.SetMode(AUTOMATIC);
        pid.SetSampleTime(.5);
        pid.SetOutputLimits(-255, 255);
        // ERROR!
        // 1 = initial memory load failed
        // 2 = DMP configuration updates failed
        // (if it's going to break, usually the code will be 1)
        Serial.print(F("DMP Initialization failed (code "));
        Serial.print(devStatus);
        Serial.println(F(")"));
    // if programming failed, don't try to do anything
    if (!dmpReady) return;
    // wait for MPU interrupt or extra packet(s) available
    while (!mpuInterrupt && fifoCount < packetSize)
        //no mpu data - performing PID calculations and output to motors
        pid.Compute();
        motorController.move(output, MIN_ABS_SPEED);
        if (currentMillis - time1Hz >= 1000)
            loopAt1Hz();
            time1Hz = currentMillis;
        if (currentMillis - time5Hz >= 5000)
            loopAt5Hz();
            time5Hz = currentMillis;
    // reset interrupt flag and get INT_STATUS byte
    // get current FIFO count
    fifoCount = mpu.getFIFOCount();
    // check for overflow (this should never happen unless our code is too inefficient)
    if ((mpuIntStatus & 0x10) || fifoCount == 1024)
        // reset so we can continue cleanly
        mpu.resetFIFO();
        Serial.println(F("FIFO overflow!"));
    // otherwise, check for DMP data ready interrupt (this should happen frequently)
    else if (mpuIntStatus & 0x02)
        // wait for correct available data length, should be a VERY short wait
        while (fifoCount < packetSize) fifoCount = mpu.getFIFOCount();
        // read a packet from FIFO
        mpu.getFIFOBytes(fifoBuffer, packetSize);
        // track FIFO count here in case there is > 1 packet available
        // (this lets us immediately read more without waiting for an interrupt)
        fifoCount -= packetSize;
        mpu.dmpGetQuaternion(&q, fifoBuffer);
        mpu.dmpGetGravity(&gravity, &q);
        mpu.dmpGetYawPitchRoll(ypr, &q, &gravity);
        #if LOG_INPUT
            Serial.print("ypr\t");
            Serial.print(ypr[0] * 180/M_PI);
            Serial.print("\t");
            Serial.print(ypr[1] * 180/M_PI);
            Serial.print("\t");
            Serial.println(ypr[2] * 180/M_PI);
        #endif
        input = ypr[1] * 180/M_PI + 180;
void loopAt1Hz()
#if MANUAL_TUNING
    setPIDTuningValues();
#endif
void loopAt5Hz()
    #if MOVE_BACK_FORTH
        moveBackForth();
    #endif
//move back and forth
void moveBackForth()
    moveState++;
    if (moveState > 2) moveState = 0;
    if (moveState == 0)
    else if (moveState == 1)
      setpoint = originalSetpoint - movingAngleOffset;
      setpoint = originalSetpoint + movingAngleOffset;
            Serial.print(setpoint); Serial.print("SP");
//PID Tuning (3 potentiometers)
#if MANUAL_TUNING
void setPIDTuningValues()
    readPIDTuningValues();
    if (kp != prevKp || ki != prevKi || kd != prevKd)
#if LOG_PID_CONSTANTS
        Serial.print(kp);Serial.print(", ");Serial.print(ki);Serial.print(", ");Serial.println(kd);
#endif
        pid.SetTunings(kp, ki, kd);
        prevKp = kp; prevKi = ki; prevKd = kd;
void readPIDTuningValues()
    int potKp = analogRead(A0);
    int potKi = analogRead(A1);
    int potKd = analogRead(A2);
    kp = map(potKp, 0, 1023, 0, 100000) / 100.0; //0 - 250
    ki = map(potKi, 0, 1023, 0, 50000) / 100.0; //0 - 1000
    kd = map(potKd, 0, 1023, 0, 5000) / 100.0; //0 - 5
#endif
