I'm inexperienced so please forgive me if the answer to this question is too obvious.
I'm moving a project I was prototyping from my Uno to a mini pro. I was using a breadboard with the Uno and had an RFID reader and a photoresistor both drawing power from the 3.3v pin and it was working as i wanted.
I will be soldering wires now and have no idea if I solder a patch for each of the RFID and photoresistor into the vcc pin (so, two wires on one pin) or, if i need to achieve this differently.
I'd be grateful for some advice or a link to where I might learn more. Everything else seems more or less straightforward to me.
If you mean you are going to solder components to the Pro-Mini I don't advise it. The standard convention for uP is to have a connector (preferably a Phoenix screw connector) and an interface cable and a separate prototype perf board. Everything that is not part of the factory made Pro-Mini gets installed on the prototype perf board (or custom PCB) and the interface cable from the peripheral board (the added board) is a ribbon cable that has female headers that simply plug into the male header pins already on the Pro-Mini (assuming you installed them) . You should start your post with a photo of your Pro-Mini and a list of what you want to add to it and how you planned to do that (where you planned to install the added components).
Thanks for these posts. I will receive my pro-mini in the mail soon i hope. I can then add more info but perhaps I can start this convo by adding a pic of what i have working on my Uno. I just want to solidify connections so I can ultimately compact and protect things. It's for an art installation that has to run all night so, from my understanding, a pro-mini is a better choice for that kind of job than an Uno.
As well, i'll likely make a back-up or two. I can see staging the piece again at some point but, for sure it must be able to run for 24 hrs connected to a PC.
We are telling people you cannot use the auxiliary regulated 3.3V from Unos, USB to TTL converters and the like to power sub-assemblies such as the ESP8266 or RC-522 RFID boards, yet I see YouTube videos demonstrating exactly that with apparent success.
