Moving Light tracking with a camera
Hi, I posted here before with an idea of indoor tracking with a moving light, however found out this wouldn't really work. I have resorted to using a camera which tracks me well in x and y keeping me in the middle of the frame. Would anyone know how or if it is possible to send the values currently going to the servos to the tinkerkit dmx shield instead so I can control the moving head with dmx (I'm using the dmx master library). The camera would sit on the moving head so it would be the same setup as what i have at the moment, the 'servos' would just be the motors in the moving head, I'm just not entirely sure how to convert the values and send them to it .
Here is the code for python:
import numpy as np
import serial
import time
import sys
import cv2
from serial import Serial
arduino = serial.Serial ('COM5', 9600)
time.sleep(2)
print("Connection to arduino...")
face_cascade = cv2.CascadeClassifier('haarcascade_frontalface_default.xml')
cap = cv2.VideoCapture(0)
while 1:
    ret, img = cap.read()
    cv2.resizeWindow('img', 500,500)
    cv2.line(img,(500,250),(0,250),(0,255,0),1)
    cv2.line(img,(250,0),(250,500),(0,255,0),1)
    cv2.circle(img, (250, 250), 5, (255, 255, 255), -1)
    gray  = cv2.cvtColor(img, cv2.COLOR_BGR2GRAY)
    faces = face_cascade.detectMultiScale(gray, 1.3)
    for (x,y,w,h) in faces:
        cv2.rectangle(img,(x,y),(x+w,y+h),(0,255,0),5)
        roi_gray  = gray[y:y+h, x:x+w]
        roi_color = img[y:y+h, x:x+w]
        arr = {y:y+h, x:x+w}
        print (arr)
        print ('X :' +str(x))
        print ('Y :'+str(y))
        print ('x+w :' +str(x+w))
        print ('y+h :' +str(y+h))
        xx = int(x+(x+h))/2
        yy = int(y+(y+w))/2
        print (xx)
        print (yy)
        center = (xx,yy)
        print("Center of Rectangle is :", center)
        data = "X{0:d}Y{1:d}Z".format(xx, yy)
        print ("output = '" +data+ "'")
        arduino.write(data)
    cv2.imshow('img',img)
    k = cv2.waitKey(30) & 0xff
    if k == 27:
        break
Here is the code loaded onto the Arduino
#include<Servo.h>
Servo servoVer; //Vertical Servo
Servo servoHor; //Horizontal Servo
int x;
int y;
int prevX;
int prevY;
  servoVer.attach(5); //Attach Vertical Servo to Pin 5
  servoHor.attach(6); //Attach Horizontal Servo to Pin 6
  servoVer.write(90);
  servoHor.write(90);
void Pos()
  if(prevX != x || prevY != y)
    int servoX = map(x, 600, 0, 70, 179);
    int servoY = map(y, 450, 0, 179, 95);
    servoX = min(servoX, 179);
    servoX = max(servoX, 70);
    servoY = min(servoY, 179);
    servoY = max(servoY, 95);
    servoHor.write(servoX);
    servoVer.write(servoY);
  if(Serial.available() > 0)
    if(Serial.read() == 'X')
      x = Serial.parseInt();
      if(Serial.read() == 'Y')
        y = Serial.parseInt();
       Pos();
    while(Serial.available() > 0)
      Serial.read();
Why wouldn’t you just use Python based DMX control?
Just does not make sense to go from Python -> Arduino -> DMX when you could be sending the DMX control direct from Python.
Slumpert:
Thanks for your reply, how would I go about that? I only know the coding for the arduino IDE to control the dmx shield
What are you running OpenCV on?
