I got a servo motor and I am trying to move him by clicking switches (pins 3, 4).
it moves clockwise when I click on switch pin 3.
and counterclockwise when I click pin 4.
the first problem - the motor moves twice and not one time.
second problem - only the led on pin 7 turn on when either switch pin 3 or 4 is clicked the third problem - when one of the switches is clicked and stay that way the motor keeps moving, I would like that the motor will move only when I release the switch and click on it again.
Thanks for the help
#include <Stepper.h> //stepper motor library
#define STEPS 2038 //define 28byj-48 stepper motor full range
Stepper stepper(STEPS, 8, 9, 10, 11); //define arduino pins for stepper motor
int SWITCH_PIN[] = {3, 4}; //define arduino pins for switchs
int LED_PIN[] = {6, 7}; //define arduino pins for leds
int CurrentSwitchPin; //initialization for switch status
int CurrentLedPin; //initialization for led status
int MotionStatus[] = {0, 0}; //initialization for motion
int z = 1; // will define the direction of the motor
Serial.begin(9600); // open serial to show prints
for (int i=0 ; i < 2; i++)
pinMode(LED_PIN[i], OUTPUT); //define led pins as outputs
pinMode(SWITCH_PIN[i], INPUT); //define switch pins as inputs
Serial.println("START!");
int MoveStepper(int Ledpin, int z)
Serial.println("MoveStepper");
digitalWrite(Ledpin, HIGH); // turn on led
stepper.setSpeed(10); // set motor speed to 10 rmp
stepper.step(255 * z); // move the motor 1/4 of the range
digitalWrite(Ledpin, LOW); // turn off after completing the motion led
z = 1;
Serial.println("stepper stop moving");
for (int x = 0; x < 2; x++)
CurrentSwitchPin = SWITCH_PIN[x]; //put swith_pin status to the arry start with pin 3
CurrentLedPin = LED_PIN[x];//put led_pin status to the arry start with pin 6
MotionStatus[x] = digitalRead(CurrentSwitchPin); //Checking input switchs
if (MotionStatus[0] == HIGH && MotionStatus[1] == LOW) //checking if switch one is pressed
MoveStepper(CurrentLedPin , -z); //moves motor clockwise
MotionStatus[0] = LOW;
if (MotionStatus[1] == HIGH && MotionStatus[0] == LOW) //checking if switch two is pressed
MoveStepper(CurrentLedPin, z); //moves motor counterclockwise
MotionStatus[1] = LOW;
Can you post a circuit diagram?
Just a hand drawn diagram showing power supply and labelled buttons etc would be fine.
It looks like your switches switch to gnd, do you have pullup resistors to pull the digital input HIGH when the switch is open?
OR
use pinMode(pinname, INPUT_PULLUP)
to turn the internal pullup resistor ON.
You are using a stepper motor, what are you using between the UNO and the stepper?
Please include it in your circuit along with how you are powering it.
the stepper motor is connected directly to the Arduino
i fixed the second problem, I don't know if it real fix or just a bypass....
added to the code:
--CurrentLedPin;
--CurrentSwitchPin;
int CurrentSwitchPin; //initialiMotionDirectionation for switch status
int CurrentLedPin; //initialiMotionDirectionation for led status
int MotionStatus[] = {0, 0}; //initialiMotionDirectionation for motion
int MotionDirection = 1; // will define the direction of the motor
pinMode(SWITCH_PIN[i], INPUT_PULLUP); //define switch pins as inputs
int MoveStepper(int Ledpin, int MotionDirection)
stepper.step(255 * MotionDirection); // move the motor 1/4 of the range
// delay(500);
MoveStepper(CurrentLedPin , MotionDirection); //moves motor counterclockwise
// Serial.println(CurrentSwitchPin);
// Serial.println(CurrentLedPin);
--CurrentLedPin;
--CurrentSwitchPin;
MoveStepper(CurrentLedPin , -MotionDirection); //moves motor clockwise
To make your motor only step once per press, you need to detect the pressing of the button, the transition from HIGH to LOW, not the fact that it is pressed LOW.
Using little 2 step for..loops is not really worth the effort when checking your buttons.
i got the driver you said.
now the motor moves real slow...
int MotionPreviousStatus;
// delay(500);
if (MotionStatus[0] == HIGH && MotionStatus[1] == LOW && (MotionPreviousStatus != MotionStatus[0])) //checking if switch one is pressed
MotionPreviousStatus = MotionStatus[0];
Serial.println("Not moving1");
Serial.println(MotionPreviousStatus);
if (MotionStatus[1] == HIGH && MotionStatus[0] == LOW && (MotionPreviousStatus != MotionStatus[1])) //checking if switch two is pressed
--CurrentLedPin;
--CurrentSwitchPin;
MotionPreviousStatus = MotionStatus[1];
Serial.println("Not moving2");
it move ones and stop moving,
i know i have problem with MotionPreviousStatus but cant find where to put it...
int MotionPreviousStatusLeft;
int MotionPreviousStatusRight;
delay(60000);
delay(6000);
if (MotionStatus[0] == HIGH && MotionStatus[1] == LOW && (MotionPreviousStatusLeft != MotionStatus[0])) //checking if switch one is pressed
MotionPreviousStatusLeft = MotionStatus[0]; //save the motion status state
else if (MotionStatus[0] == LOW)
MotionPreviousStatusLeft = LOW;
if (MotionStatus[1] == HIGH && MotionStatus[0] == LOW && (MotionPreviousStatusRight != MotionStatus[1])) //checking if switch two is pressed
--CurrentLedPin;
--CurrentSwitchPin;
MotionPreviousStatusRight = MotionStatus[1];
else if (MotionStatus[1] == LOW)
MotionPreviousStatusRight = LOW;
