Moving motors in sequence with Sensors
Starting with 3 sensors and 3 motors.
Each motor is connected to a gate within a maze. Gates 1 and 2 are open at the start of the experiment. Gate three is closed.
A proximity sensor is placed after each gate. Sensor 1, when triggered, while cause two actions:
  • motor 1 to rotate 90 degrees counterclockwise (to close gate 1),
  • and motor 3 to rotate 90 degrees clockwise (to open gate 3).
The remaining two sensors will open and close the other two gates in a similar fashion.
Currently, the problem that I am having is that when the code is uploaded motor 1 rotates 90 degrees without sensor 1 being triggered. Nothing happens when the other sensors are triggered.
I have checked all my wiring, multiple arduino boards, different motors and sensors.
Also, can anyone who has used these motors confirm if I have specified the steps, pins, and speeds correctly? Trying to use only two pins (not all 4) from the step motor controller.
Using 28BYJ-48 5V Step Motors with the drivers that came with them.
#include <Stepper.h>
const int stepsPerRevolution = 512;
//declaring pins for motors 1, 2, and 3 (motors will be configured to rotate clockwise 90 degrees (open position) or rotate counter clockwise 90 degrees (closed position))
Stepper motor1(stepsPerRevolution, 1, 2, 1, 2);
Stepper motor2(stepsPerRevolution, 3, 4, 3, 4);
Stepper motor3(stepsPerRevolution, 5, 6, 5, 6);
// declaring pins for proximity sensors 1, 2, and 3
int sensor1 = 8;
int sensor2 = 9;
int sensor3 = 10;
//seting up variables to read sensor values (low when triggered, high when not triggered)
int sensor1value;
int sensor2value;
int sensor3value;
// setting up counters which i am using to prevent motors from changing states (open or closed) until subsequent conditions are met
int sensor1counter;
int sensor2counter;
int sensor3counter;
//defining motor states
int counter1 = 0; //open
int counter2 = 0; //open
int counter3 = 1; //closed
pinMode(sensor1, INPUT);
pinMode(sensor2, INPUT);
pinMode(sensor3, INPUT);
motor1.setSpeed(60);
motor2.setSpeed(60);
motor3.setSpeed(60);
//read sensor values
sensor1value = digitalRead(sensor1);
sensor2value = digitalRead(sensor2);
sensor3value = digitalRead(sensor3);
if (sensor1value == LOW); //if sensor 1 is triggered
if (counter1 == 0) //and if gate 1 is open
motor1.step(-544); //rotate motor 1 counterclockwise 90 degrees (close gate 1)
counter1 = 1; //note that gate 1 is now closed
motor3.step(544); //rotate motor 3 clockwise 90 degrees (open gate 3)
counter3 = 0; //note that gate 3 is now open
if (sensor2value == LOW);
if (counter2 == 0)
motor2.step(-544);
counter2 = 1;
motor1.step(544);
counter1 = 0;
if (sensor3value == LOW);
if (counter3 == 0);
motor3.step(-544);
counter3 = 1;
motor2.step(544);
counter2 = 0;
So what is your issue? Does the program do anything? What does it do that is different from what you want?
You have no comments with useful information like if a sensor counts as triggered when it's high or low or when a gate is open or closed. I'm not going to try to guess what the program is doing.
Steve
First thing you should notice 28BYJ-48 5V Step Motor’s pins. Because of i had it a long time ago for building my first cnc plotter. When i compile it motors just vibrated not turned. I was figure it out with check out of the motors wire and there was wrong of wiring.
So be carefull with 28BYJ-48 stepper motors. :wink:
Thank you, just updated new code, comments, background, and trouble shooting.
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Can you post a table showing
All sensors OFF, which gates open/closed
Sensor 1 triggered, which gates open/closed
Sensor 2 triggered, which gates open/closed
Sensor 3 triggered, which gates open/closed
Can there be a situation where more than one sensor is triggered.
By drawing a table you can easily see how your logic needs to work.
This could use the switch … case type function
https://www.arduino.cc/reference/en/language/structure/control-structure/switchcase/
Tom… :slight_smile:
What would lead anyone to believe that the code does what the comment suggests that it does?
It is extremely rare for an if statement to end with a ;.
If you are using sensors to open the gates, are you going to delay when the gate closes after the sensor deactivates, so people can clear the gateway?
  • How are you controlling your steppers.
  • How are you powering the project.
  • Have you written code just to test the stepper drivers and stepper motors?
Tom.... :slight_smile:
