Moving servo from website on SD card
Hello everybody
i am working on a project for my model railway. i want to use a servo motor for moving the turnouts instead of the more expensive turnout motors.
First i was able to make i work by having the HTML code embedded in the arduino code.
next step was to put the HTML code on the sd card. I the tried to make this code:
#include <Servo.h>
#include <Ethernet.h>
#include <SPI.h>
#include <SD.h>
byte mac[] = { 0x90, 0xA2, 0xDA, 0x0D, 0xA6, 0x2B };
byte ip[] = { 192, 168, 1, 178 };
("192.168.1.178")
byte gateway[] = { 192, 168, 1, 1 };
byte subnet[] = { 255, 255, 255, 0 };
EthernetServer server(80);
String readString;
File webFile;
// constant variables used to set servo angles, in degrees
const int straight = 80;
const int divergent = 130;
// constant variables holding the ids of the pins we are using
const int buttonpin = 8;
const int servopin = 9;
// servo movement step delay, in milliseconds
const int step_delay = 70;
// create a servo object
Servo myservo;
// global variables to store servo position
int pos = straight; // current
int old_pos = pos; // previous
 Ethernet.begin(mac, ip);  // initialize Ethernet device
 server.begin();           // start to listen for clients
 // set the mode for the digital pins in use
 pinMode(buttonpin, INPUT);
 // setup the servo
 myservo.attach(servopin);  // attach to the servo on pin 9
 myservo.write(pos); // set the initial servo position
 Ethernet.begin(mac, ip, gateway, subnet);
 server.begin();
 Serial.print("server is at ");
 Serial.println(Ethernet.localIP());
  // initialize SD card
   Serial.println("Initializing SD card...");
   if (!SD.begin(4)) {
       Serial.println("ERROR - SD card initialization failed!");
       return;    // init failed
   Serial.println("SUCCESS - SD card initialized.");
   // check for index.htm file
   if (!SD.exists("index.htm")) {
       Serial.println("ERROR - Can't find index.html file!");
       return;  // can't find index file
   Serial.println("SUCCESS - Found index.html file.");
 if (client)
   boolean currentLineIsBlank = true;
   while (client.connected())
      if (client.available())
       char c = client.read();
       //read char by char HTTP request
       if (readString.length() < 100)
         //store characters to string
         readString += c;
         //Serial.print(c);
        //if HTTP request has ended
        if (c == '\n')
          Serial.println(readString); //print to serial monitor for debuging
          client.println("HTTP/1.1 200 OK"); //send new page
          client.println("Content-Type: text/html");
          client.println();
           webFile = SD.open("index.htm");        // open web page file
                   if (webFile) {
                       while(webFile.available()) {
                           client.write(webFile.read()); // send web page to client
                       webFile.close();
               // every line of text received from the client ends with \r\n
               if (c == '\n') {
                   // last character on line of received text
                   // starting new line with next character read
               else if (c != '\r') {
                   // a text character was received from client
                   currentLineIsBlank = false;
           } // end if (client.available())
       } // end while (client.connected())
       delay(1);      // give the web browser time to receive the data
       client.stop(); // close the connection
   } // end if (client)
   old_pos = pos;   // save the current position
   // Toggle the position to the opposite value
   pos = pos == straight ? divergent: straight;
   if (readString.indexOf("?button2on") >0)
     // Move the servo to its new position
     if(old_pos < pos)
     {   // if the new angle is higher
       // increment the servo position from oldpos to pos
       for(int i = old_pos + 1; i <= pos; i++)
         myservo.write(i); // write the next position to the servo
         delay(step_delay); // wait
     {  // otherwise the new angle is equal or lower
       // decrement the servo position from oldpos to pos
       for(int i = old_pos - 1; i >= pos; i--)
Now the servo just moves from side to side and doesn’t care if i press the button or not.
i think that i has something to do with this part:
But i´m not sure what to write in the if statement…
Pleace help me.
("192.168.1.178")
What is this supposed to do?
What's with all the stupid white space? Clean up your code before wasting our time.
So, you know what the client requested. That makes one of us.
Unless you share what the GET request looked like, we'll have to go with your guessing.
Add some Serial.print() statements after that if statement, to see what the Arduino decided.
PaulS:
("192.168.1.178")
first of all thank you for your kind reply.. i´m sorry if i wasted your time with "all of the stupid white space"
if you care to take a look at the left of my post it says that i´m a newbie at this. So once again i am sorry to waste your time with my question. but then again i did not ask for you to comment on my problem if it was to be any kind of a way to ruin your day.
Thank you for that one advise at the very end of your reply...i will try that.
have at nice day and a HAPPY new year..
i´m sorry if i wasted your time with “all of the stupid white space”
Only be sorry that somebody was probably potty trained on a electric chair. I’ve attached some files that make a web page slider setup for servos which is served up from an SD card. Not exactly what you are looking for, but you can see some of the basic concepts.
slider files.zip (6.11 KB)
Come on, everyone. Try a little harder to be nice to each other. It's New Year's Eve for goodness sake. Try to relax and enjoy each others' companies. Or if that isn't possible, write an insulting reply, and then delete it rather than posting it. It is quite therapeutic doing that. :slight_smile:
@PaulS: Let me rephrase that for you:
Your excessive use of white space makes the code difficult to read. If you bought a book with a lot of excessive gaps between lines you would find it hard to read.
Hello Nick and Zoomcat
and thank you for replying
i haven´t had the time to look further into the slider files but i definitely will as soon as possible as far as i can tell it is possible to build it further into what i am trying to achieve
@Nick Gammon
I will try to minimize my use of white space. i hope that you had a great new year :slight_smile:
