moving stepper motor 28byj48
Hello
i create an application which connects with a server and finally with Arduino and stepper motor. everythinf is fine Arduino receives 1 for moving stepper clockwise and 0 counterclockwise.
if found that code and work fine
//declare variables for the motor pins
int motorPin1 = 8; // Blue - 28BYJ48 pin 1
int motorPin2 = 9; // Pink - 28BYJ48 pin 2
int motorPin3 = 10; // Yellow - 28BYJ48 pin 3
int motorPin4 = 11; // Orange - 28BYJ48 pin 4
// Red - 28BYJ48 pin 5 (VCC)
int motorSpeed ; //variable to set stepper speed
//declare the motor pins as outputs
pinMode(motorPin1, OUTPUT);
pinMode(motorPin2, OUTPUT);
pinMode(motorPin3, OUTPUT);
pinMode(motorPin4, OUTPUT);
void loop(){
// if (2 < 3){ // if potentiometer reads 0 to 535 do this
motorSpeed = (33); //scale potValue to be useful for motor
clockwise(); //go to the ccw rotation function
// else { //value of the potentiometer is 512 - 1024
// motorSpeed = (33); //scale potValue for motor speed
// counterclockwise(); //go the the cw rotation function
//set pins to ULN2003 high in sequence from 1 to 4
//delay "motorSpeed" between each pin setting (to determine speed)
void counterclockwise (){
// 1
digitalWrite(motorPin1, HIGH);
digitalWrite(motorPin2, LOW);
digitalWrite(motorPin3, LOW);
digitalWrite(motorPin4, LOW);
delay(motorSpeed);
// 2
digitalWrite(motorPin2, HIGH);
delay (motorSpeed);
// 3
digitalWrite(motorPin1, LOW);
delay(motorSpeed);
// 4
digitalWrite(motorPin3, HIGH);
delay(motorSpeed);
// 5
delay(motorSpeed);
// 6
digitalWrite(motorPin4, HIGH);
delay (motorSpeed);
// 7
delay(motorSpeed);
// 8
delay(motorSpeed);
//set pins to ULN2003 high in sequence from 4 to 1
void clockwise(){
// 1
delay(motorSpeed);
// 2
delay (motorSpeed);
// 3
delay(motorSpeed);
// 4
delay(motorSpeed);
// 5
delay(motorSpeed);
// 6
delay (motorSpeed);
// 7
delay(motorSpeed);
// 8
delay(motorSpeed);
however
i place that code in my project and stepper motor didnt rotate. the "1" and "0" transmited fine to Arduino.
could you please help me.
thank you in advance
#include <WiFi.h>
#include <SoftwareSerial.h>
int motorSpeed =5; //variable to set stepper speed
// Your network SSID (network name).
// TODO: Enter the name of your wifi network here.
char ssid[] = "Tzavelas";
// Your network password.
// TODO: Enter the password of your wifi network here.
char pass[] = "mypass";
// Your network key Index number (needed only for WEP).
int keyIndex = 0;
// Server status flag.
int status = WL_IDLE_STATUS;
// Create WiFi server listening on the given port.
WiFiServer server(4001);
// Start serial communication with the given baud rate.
// NOTE: Remember to set the baud rate in the Serial
// monitor to the same value.
// Wait for serial port to connect. Needed for Leonardo only
while (!Serial) { ; }
// Check for the presence of the WiFi shield.
if (WiFi.status() == WL_NO_SHIELD)
// If no shield, print message and exit setup.
Serial.println("WiFi shield not present");
status = WL_NO_SHIELD;
return;
String version = WiFi.firmwareVersion();
if (version != "1.1.0")
Serial.println("Please upgrade the firmware");
// Connect to Wifi network.
while (status != WL_CONNECTED)
Serial.print("Connecting to Network named: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network. Update this line if
// using open or WEP network.
status = WiFi.begin(ssid, pass);
// Wait for connection.
// Start the server.
server.begin();
// Print WiFi status.
printWifiStatus();
// Check that we are connected.
if (status != WL_CONNECTED)
return;
// Listen for incoming client requests.
WiFiClient client = server.available();
if (!client)
return;
Serial.println("Client connected");
String request = readRequest(&client);
//executeRequest(&client, &request);
// Close the connection.
//client.stop();
Serial.println("Client disonnected");
// Read the request line. The string from the JavaScript client ends with a newline.
String readRequest(WiFiClient* client)
String request = "";
// Loop while the client is connected.
while (client->connected())
// Read available bytes.
while (client->available())
// Read a byte.
char c = client->read();
// Print the value (for debugging).
Serial.write(c);
if (c == '1'){
int microsteps=100;
for (int i = 0; i<microsteps; i++) // Iterate for 4000 microsteps.
// unsigned long start = millis();
// while (millis() - start <= 5000)
//motorSpeed = (5); //scale potValue to be useful for motor
Serial.write("move up");
else {
int microsteps=100;
Serial.write("move down");
// Exit loop if end of line.
if ('\n' == c)
return request;
// Add byte to request line.
request += c;
void printWifiStatus()
Serial.println("WiFi status");
// Print network name.
Serial.print(" SSID: ");
Serial.println(WiFi.SSID());
// Print WiFi shield IP address.
IPAddress ip = WiFi.localIP();
Serial.print(" IP Address: ");
Serial.println(ip);
// Print the signal strength.
long rssi = WiFi.RSSI();
Serial.print(" Signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
void counterclockwise ()...............
void clockwise()....................
this is my code
my code is in the second post..
