moving two servos with one switch
I have two servos wired up to my bread board one is connected to pin 8 and one to pin 9 i have my code set up but it is only moving one servo can any one see a problem with the code?
#include <Servo.h>
Servo myServo;
int const potPin = A0;
int potVal;
int angle;
myServo.attach(8);
myServo.attach(9);
potVal = analogRead(potPin);
Serial.print("potval; ");
Serial.print(potVal);
angle = map(potVal, 0 - 900, 1023, 1 - 147, 150);
Serial.print (", angle: ");
Serial.println(angle);
myServo.write(angle);
delay(15);
I want both servos to move at the exact same time.
Thanks
Is it the 2nd one that moves?
  myServo.attach(8);
  myServo.attach(9);
Add a 2nd one:
Servo myServo;
Servo myServo1;
  myServo1.attach(9);
myServo.write1(angle);
Yep I just worked it out thanks.
Bit of a novice over here!
http://forum.arduino.cc/index.php?topic=280819.0
I am now getting an error message Expected initialiser before void on the void setup() part of the code
#include <Servo.h>
Servo myServo;
Servo myServos;
int potVal;
int angle;
int agnles
myServo.attach(8);
myServos.attach(9);
angles = map(potVal, 900 - 0, 1023, 147 - 1, 150);
myServos.write(angles);
delay(15);
Please use [ code ] tags.
You forgot a semicolon. When you get an error like that, look at the line before.
This line here is hosed
int agnles - misspelled per later usage:
and missing ; at the end as MorganS said.
