MOXA Ethernet to RS232 For Arduino
Hello
I am working with an Arduino connected via RS232.
I am using : Labview --> Moxa Ethernet to RS232 -->MAX323 (to TTL 5V)--> Arduino UNO
I can see the MOXA box ON when I send something via Labview but I can't communicate with the Arduino...
I would like to try a simple application : controlling the LED (pin 13) via Labview.
I am connecting on pin 0 and 1 for the serial communication.
I have tried this method as well : https://www.arduino.cc/en/Tutorial/ArduinoSoftwareRS232
But Labview and the Arduino don't seem to talk.
As I use the MOXA, I guess I need to use VISA because the Arduino is not seen as a COM port anymore
I hope you can help !
Thank you :slight_smile:
And I am using this device as MAX323 : http://www.farnell.com/datasheets/2019648.pdf?_ga=1.113122948.1010162443.1488884493
So I have simply connected
Power to 5V (
GND to GND
RX to TX(pin 1)
TX to RX (pin 0)
