Mozzi Library with Arcore Library MIDI note off issue
Hi. I’m working on a very basic synthesizer using the Mozzi Audio Library and rkistner’s Arcore library to use USB MIDI. Everything is working great except for an annoying hiccup where any note off message received will cause all of the MIDI notes to stop sounding. I suspect that the reason for this is related to Mozzi’s ADSR Class. Documentation here: Mozzi: ADSR< CONTROL_UPDATE_RATE, LERP_RATE > Class Template Reference
Here is the code that I am working with:
#include <MIDI.h>
#include <MozziGuts.h>
#include <Oscil.h> // oscillator template
#include <tables/sin2048_int8.h> // sine table for oscillator
#include <mozzi_midi.h>
#include <ADSR.h>
MIDI_CREATE_DEFAULT_INSTANCE();
#define AUDIO_MODE STANDARD_PLUS
// use #define for CONTROL_RATE, not a constant
#define CONTROL_RATE 128 // powers of 2 please
// audio sinewave oscillator
Oscil <SIN2048_NUM_CELLS, AUDIO_RATE> aSin(SIN2048_DATA);
// envelope generator
ADSR <CONTROL_RATE, AUDIO_RATE> envelope;
#define LED 2 // shows if MIDI is being recieved
void HandleNoteOn(byte channel, byte note, byte velocity) {
  aSin.setFreq(mtof(float(note)));
  envelope.noteOn();
  digitalWrite(LED,HIGH);
void HandleNoteOff(byte channel, byte note, byte velocity) {
  envelope.noteOff();
  digitalWrite(LED,LOW);
  pinMode(LED, OUTPUT);
  //envelope.setADLevels(0,0);
  //envelope.setTimes(5,200000,10000,5); // 10000 is so the note will sustain 10 seconds unless a noteOff comes
  aSin.setFreq(440); // default frequency
  startMozzi(CONTROL_RATE);
void updateControl(){
  while(MIDIUSB.available() > 0) {  // Repeat while notes are available to read.
      MIDIEvent e;
      e = MIDIUSB.read();
      if(e.type == 0x09) { //note on message
         HandleNoteOn(1, e.m2, 127);//channel, note velocity (does not include message type)
         //For Debugging
         Serial.println("e.m1: ");
         Serial.println(e.m1);
         Serial.println("e.m2: ");
         Serial.println(e.m2);
         Serial.println("e.m3: ");
         Serial.println(e.m3);
      if(e.type == 0x08) {
         HandleNoteOff(1, e.m2, 0); //channel, note, velocity (does not include message type)
         //For Debugging
         Serial.println("noteOff");
      MIDIUSB.flush();
  envelope.update();
int updateAudio(){
  return (int) (envelope.next() * aSin.next())>>8;
  audioHook(); // required here
Note: It requires the Mozzi Library available here: http://sensorium.github.io/Mozzi/
and it requires the Arcore Library available here: GitHub - rkistner/arcore: MIDI-USB Support for Arduino
Any thoughts or ideas would be greatly appreciated!
For anyone interested I found a solution in the Mozzi google group. You can view it here: https://groups.google.com/forum/#!topic/mozzi-users/A8xavm1YFxc
