MP3 grove player
j'ai un probleme avec ce code :
//    Function: control the seeedstudio Grove MP3 player
//      Hardware: Grove - Serial MP3 Player
#include <SoftwareSerial.h>
SoftwareSerial mp3(2, 3);//modify this with the connector you are using.
    mp3.begin(9600);
    delay(100);
    if (true ==SetPlayMode(0x01))
    Serial.println("Set The Play Mode to 0x01, Single Loop Mode.");
    Serial.println("Playmode Set Error");
    PauseOnOffCurrentMusic();
    SetPlayMode(0x01);
    SetMusicPlay(00,01);
    SetVolume(0x0E);
    while(1);
//Set the music index to play, the index is decided by the input sequence
//of the music;
//hbyte: the high byte of the index;
//lbyte: the low byte of the index;
boolean SetMusicPlay(uint8_t hbyte,uint8_t lbyte)
    mp3.write(0x7E);
    mp3.write(0x04);
    mp3.write(0xA0);
    mp3.write(hbyte);
    mp3.write(lbyte);
    mp3.write(0x7E);
    delay(10);
    while(mp3.available())
        if (0xA0==mp3.read())
        return true;
        return false;
// Pause on/off  the current music
boolean PauseOnOffCurrentMusic(void)
    mp3.write(0x7E);
    mp3.write(0x02);
    mp3.write(0xA3);
    mp3.write(0x7E);
    delay(10);
        if (0xA3==mp3.read())
        return true;
        return false;
//Set the volume, the range is 0x00 to 0x1F
boolean SetVolume(uint8_t volume)
    mp3.write(0x7E);
    mp3.write(0x03);
    mp3.write(0xA7);
    mp3.write(volume);
    mp3.write(0x7E);
    delay(10);
        if (0xA7==mp3.read())
        return true;
        return false;
boolean SetPlayMode(uint8_t playmode)
    if (((playmode==0x00)|(playmode==0x01)|(playmode==0x02)|(playmode==0x03))==false)
        Serial.println("PlayMode Parameter Error! ");
        return false;
    mp3.write(0x7E);
    mp3.write(0x03);
    mp3.write(0xA9);
    mp3.write(playmode);
    mp3.write(0x7E);
    delay(10);
        if (0xA9==mp3.read())
        return true;
        return false;
Tout s'allume mais la meme musique tourne en boucle alors que c'est censé changer de musique. Je ne vois d'erreur particuliere dans le code alors je ne vois pas d'ou ca vient. Une idée peut-être ?
Merci d'avance, ardublop
