Mp3 player VS1053 geeetech.com
Bonjour,
J’aimerai réaliser un lecteur mp3 avec la shield VS1053.
La lecture des mp3 fonctionne mais le programme semble occupé à lire le mp3 et je ne peux rien faire pendant ce temps la.
Il semblerait qu’on peut lire un mp3 en fond mais je ne comprends pas comment ca marche.
Je voudrais utiliser un keypad pour piloter le lecteur : play, pause, sélection du mp3…etc
Mon code :
  This is an example for the Adafruit VS1053 Codec Breakout
  Designed specifically to work with the Adafruit VS1053 Codec Breakout
  ----> https://www.adafruit.com/products/1381
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries.
  BSD license, all text above must be included in any redistribution
// include SPI, MP3 and SD libraries
#include <SPI.h>
#include <Adafruit_VS1053.h>
#include <SD.h>
#include <Keypad.h>
// define the pins used
#define CLK 13       // SPI Clock, shared with SD card
#define MISO 12      // Input data, from VS1053/SD card
#define MOSI 11      // Output data, to VS1053/SD card
// Connect CLK, MISO and MOSI to hardware SPI pins.
// See http://arduino.cc/en/Reference/SPI "Connections"
// These are the pins used for the breakout example
#define BREAKOUT_RESET  8      // VS1053 reset pin (output)
#define BREAKOUT_CS     6     // VS1053 chip select pin (output)
#define BREAKOUT_DCS    7      // VS1053 Data/command select pin (output)
// These are the pins used for the music maker shield
#define SHIELD_RESET  -1      // VS1053 reset pin (unused!)
#define SHIELD_CS     6      // VS1053 chip select pin (output)
#define SHIELD_DCS    7      // VS1053 Data/command select pin (output)ut)
// These are common pins between breakout and shield
#define CARDCS 9     // Card chip select pin
// DREQ should be an Int pin, see http://arduino.cc/en/Reference/attachInterrupt
#define DREQ 2       // VS1053 Data request, ideally an Interrupt pin
Adafruit_VS1053_FilePlayer musicPlayer =
  // create breakout-example object!
  Adafruit_VS1053_FilePlayer(BREAKOUT_RESET, BREAKOUT_CS, BREAKOUT_DCS, DREQ, CARDCS);
  // create shield-example object!
  //Adafruit_VS1053_FilePlayer(SHIELD_RESET, SHIELD_CS, SHIELD_DCS, DREQ, CARDCS);
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
//define the cymbols on the buttons of the keypads
char hexaKeys[ROWS][COLS] = {
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}
byte rowPins[ROWS] = {A0, A1, A2, A3}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {A4, A5, 4, 5}; //connect to the column pinouts of the keypad
//initialize an instance of class NewKeypad
Keypad customKeypad = Keypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
  Serial.println("Adafruit VS1053 Library Test");
  pinMode(0, OUTPUT);
  // initialise the music player
  if (! musicPlayer.begin()) { // initialise the music player
     Serial.println(F("Couldn't find VS1053, do you have the right pins defined?"));
     while (1);
  Serial.println(F("VS1053 found"));
  musicPlayer.sineTest(0x44, 500);    // Make a tone to indicate VS1053 is working
  if (!SD.begin(CARDCS)) {
    Serial.println(F("SD failed, or not present"));
    while (1);  // don't do anything more
  Serial.println("SD OK!");
  // list files
  printDirectory(SD.open("/"), 0);
  // Set volume for left, right channels. lower numbers == louder volume!
  musicPlayer.setVolume(20,20);
  /***** Two interrupt options! *******/
  // This option uses timer0, this means timer1 & t2 are not required
  // (so you can use 'em for Servos, etc) BUT millis() can lose time
  // since we're hitchhiking on top of the millis() tracker
  //musicPlayer.useInterrupt(VS1053_FILEPLAYER_TIMER0_INT);
  // This option uses a pin interrupt. No timers required! But DREQ
  // must be on an interrupt pin. For Uno/Duemilanove/Diecimilla
  // that's Digital #2 or #3
  // See http://arduino.cc/en/Reference/attachInterrupt for other pins
  // *** This method is preferred
  if (! musicPlayer.useInterrupt(VS1053_FILEPLAYER_PIN_INT))
    Serial.println(F("DREQ pin is not an interrupt pin"));
  // Alternately, we can just play an entire file at once
  // This doesn't happen in the background, instead, the entire
  // file is played and the program will continue when it's done!
  if (! musicPlayer.startPlayingFile("TRACK001.MP3")) {
    Serial.println("Could not open file TRACK001.MP3");
    while (1);
   // musicPlayer.playFullFile("track001.mp3");
  char customKey = customKeypad.getKey();
  //Serial.println(".");
  if (customKey){
    Serial.println(customKey);
  if (customKey=='1'){
    musicPlayer.stopPlaying();
/// File listing helper
void printDirectory(File dir, int numTabs) {
   while(true) {
     File entry =  dir.openNextFile();
     if (! entry) {
       // no more files
       //Serial.println("**nomorefiles**");
     for (uint8_t i=0; i<numTabs; i++) {
       Serial.print('\t');
     Serial.print(entry.name());
     if (entry.isDirectory()) {
       Serial.println("/");
       printDirectory(entry, numTabs+1);
       // files have sizes, directories do not
       Serial.print("\t\t");
       Serial.println(entry.size(), DEC);
     entry.close();
