Dear experts,
I was trying to use IR with Sparkfun MP3 shiled, for the purpose I used the example available in the sparkfun library by the name of "MP3ButtonPlayer2". The remote O am using is by ketes, I have decoded all the keys through IR library. However, when I compile and upload the code to arduino I dont get anything on the serial monitor except for the message "Looking for Buttons to be depressed...". If I upload the un modified code it does play mp3 tracks without any problem. I was just wondering is there something wrong with the code or is there a syntax problem sensor and Arduino work otherwise, I am a relative newbie to coding. Code is as follows:
* \file MP3ButtonPlayer2.ino
* \brief Example sketch of using the MP3Shield Arduino driver using buttons,
* with arduino recommended(simpler) debounce library
* \remarks comments are implemented with Doxygen Markdown format
* \author Michael P. Flaga
* This sketch demonstrates the use of digital input pins used as buttons as
* NEXT, PLAY and STOP to control the tracks that are to be played.
* Where PLAY or STOP will begin or cancel the stream of track000.mp3 through
* track999.mp3, as indexed by NEXT, begining with 0.
* \note Use this example uses the bounce2 library to provide debouncing fuctions. Advocated by Arduino's website at http://playground.arduino.cc/code/bounce
// libraries
#include <SPI.h>
#include <SdFat.h>
#include <SFEMP3Shield.h>
#include <Bounce2.h>
#include "IRremote.h"
* \breif Macro for the debounced NEXT pin, with pull-up
#define B_NEXT A0
* \breif Macro for the debounced STOP pin, with pull-up
#define B_STOP A1
* \breif Macro for the debounced PLAY pin, with pull-up
#define B_PLAY A2
* \breif Macro for the Debounce Period [milliseconds]
#define BUTTON_DEBOUNCE_PERIOD 20 //ms
* \brief Object instancing the SdFat library.
* principal object for handling all SdCard functions.
SdFat sd;
* \brief Object instancing the SFEMP3Shield library.
* principal object for handling all the attributes, members and functions for the library.
SFEMP3Shield MP3player;
* \brief Object instancing the Next Button.
Bounce b_Next = Bounce();
* \brief Object instancing the Stop Button library.
Bounce b_Stop = Bounce();
* \brief Object instancing the Play Button library.
Bounce b_Play = Bounce();
* \brief Index of the current track playing.
* Value indicates current playing track, used to populate "x" for playing the
* filename of "track00x.mp3" for track000.mp3 through track254.mp3
int receiver = 4; // Signal Pin of IR receiver to Arduino Digital Pin 6
int8_t current_track = 0;
IRrecv irrecv(receiver); // create instance of 'irrecv'
decode_results results; // create instance of 'decode_results'
* \brief Setup the Arduino Chip's feature for our use.
* After Arduino's kernel has booted initialize basic features for this
* application, such as Serial port and MP3player objects with .begin.
irrecv.enableIRIn(); // Start the receiver
pinMode(B_NEXT, INPUT_PULLUP);
pinMode(B_STOP, INPUT_PULLUP);
pinMode(B_PLAY, INPUT_PULLUP);
b_Next.attach(B_NEXT);
b_Next.interval(BUTTON_DEBOUNCE_PERIOD);
b_Stop.attach(B_STOP);
b_Stop.interval(BUTTON_DEBOUNCE_PERIOD);
b_Play.attach(B_PLAY);
b_Play.interval(BUTTON_DEBOUNCE_PERIOD);
if(!sd.begin(9, SPI_HALF_SPEED)) sd.initErrorHalt();
if (!sd.chdir("/")) sd.errorHalt("sd.chdir");
MP3player.begin();
MP3player.setVolume(10,10);
Serial.println(F("Looking for Buttons to be depressed..."));
* \brief Main Loop the Arduino Chip
* This is called at the end of Arduino kernel's main loop before recycling.
* And is where the user's is executed.
* \note If the means of refilling is not interrupt based then the
* MP3player object is serviced with the availaible function.
// Below is only needed if not interrupt driven. Safe to remove if not using.
#if defined(USE_MP3_REFILL_MEANS) \
&& ( (USE_MP3_REFILL_MEANS == USE_MP3_SimpleTimer) \
|| (USE_MP3_REFILL_MEANS == USE_MP3_Polled) )
MP3player.available();
#endif
//Do something. Have fun with it.
if (irrecv.decode(&results)) // have we received an IR signal?
if (results.value == 0xFF629D)
Serial.print(F("B_PLAY pressed, Start Playing Track # "));
MP3player.playTrack(current_track);
delay(2000);
} if (results.value == 0xFFC23D) {
Serial.print(F("B_STOP pressed, Stopping Track #"));
Serial.println(current_track);
MP3player.stopTrack();
delay(2000);
} if (results.value == 0xFF02FD) {
Serial.print(F("B_NEXT pressed, Start Playing Next Track #"));
Serial.println(++current_track);
(++current_track);
delay(2000);
irrecv.resume(); // receive the next value
