MPC4631 digipot
Hi, first time trying to do something.
Board - arduino nano.
I got few pieces of this digipot:
The units I got are dual 50k volatile pots, I2C interface
Trying to read the specs, but I miss one thing: Could I control the two pots independantly?
As far as I understand, the device is controled via the HVC/AO
Depending on A1 and A2 being connected to gnd or vcc, I get different addres for the device.
Is that an address for the whole device, or I can control which pot inside the device I am currently controlling?
Regards
I managed to control seporately the pots inside the device,but just one by one.
Sending data to HVC/A0 controls one of the pots.
Then I plugged the data to the pot's A1 and controlled the other.
I think, if both connected, A0 takes precedence.
This is not usefull for certain applications, where I would like to control the pots inside simultaneously or independently.
The thing I do not understand is where in the I2C wire library functions we set which controler I/O sends the data ?????
Whichever is connected??
Here is the code I used: https://www.arduino.cc/en/Tutorial/DigitalPotentiometer
"wire.write()" sends data to... which pin of the controller????
