MPL115A2 change SPI pin communication
I got a MPL115A2 adafruit sensor on a Arduino uno r3 board.
I use the <Adafruit_MPL115A2.h> Library.
The SCL and SDA of the MPL115A2 are respectly connected to analog pin 5 and 4 on the arduino.
I also have a XBEE pro 900 module connected to the arduino board.
Question: I want to free the analog pin 5 and 4 on the arduino and put the SPI communication of the MPL115A2 on digital pin 9 and 8 of the arduino.
IF someone can help…thank a lot to the community for the help…very appreciate…
:wink:
Alain
What makes you think the sensor can be used in SPI mode ?
Why do you want to free pin A4 and A5 ? Perhaps you could use a mux to be able to select more analog signals.
Excuse I was wrong not SPI but I2C communication and if I could change SCL and SDA (Ana5 and Ana4) on Arduino Uno I'll not have to multiplex.
Thank for the help
Alain
On a Arduino boards, the I2C pins are fixed to certain pins, You can not change it.
For the Arduino Uno it is A4 and A5, at the cost of 2 analog inputs. The Arduino Mega 2560 has 16 analog inputs. http://arduino.cc/en/Main/arduinoBoardMega2560 The Arduino Leonardo has 12 analog inputs. http://arduino.cc/en/Main/arduinoBoardLeonardo
Nick Gammon wrote a page about using a mux. http://www.gammon.com.au/forum/?id=11976
