MPR121 and Redboard
Hello,
I'm trying to get my Adafruit mpr121 touch sensor hooked up to my sparkfun redboard but I can't get it to work. I wired it as in the instructions and used the sample code, modified like in This post to prevent it from stopping whenever it gets no response, but I just keep getting "Not found."
Here is an image of my wiring:
Is there something I'm doing wrong? Or is my sensor just a dud?
Did you have an Arduino question?
I cannot find an image in your post.
You must have modified the sketch as the original example doesn't print out above string. Post the code of your sketch and don't forget the code tags!
Did you run an I2C scanner?
