Hello!
I want it to work smoothly every second without blinking.
PLease help!
The link below is the video of using Arduino.
#include <Wire.h>
#include <MPU6050.h>
MPU6050 mpu;
int RED = 11;
int GREEN = 10;
int BLUE = 6;
int WHITE = 9;
const int rgbLedPin = 13;
const int whiteLedPin = 2;
const int batteryVoltagePin = A0;
int currentFunction = 0;
unsigned long functionStartTime = 0;
const unsigned long warmupDuration = 3600000UL; // Milliseconds, make sure to use UL for unsigned long
#define RAD_TO_DEG 180.0 / PI
Wire.begin();
mpu.initialize();
pinMode(RED, OUTPUT);
pinMode(GREEN, OUTPUT);
pinMode(BLUE, OUTPUT);
pinMode(WHITE, OUTPUT);
pinMode(rgbLedPin, OUTPUT);
pinMode(whiteLedPin, OUTPUT);
pinMode(batteryVoltagePin, INPUT);
int16_t accelX, accelY, accelZ;
mpu.getAcceleration(&accelX, &accelY, &accelZ);
Serial.print("Acceleration: X = ");
Serial.print(accelX);
Serial.print(", Y = ");
Serial.print(accelY);
Serial.print(", Z = ");
Serial.println(accelZ);
int batteryValue = analogRead(batteryVoltagePin);
float voltage = batteryValue * (5.0 / 1023.0);
Serial.print("Battery Voltage: ");
Serial.println(voltage);
if (voltage < 3.6) {
analogWrite(rgbLedPin, 26);
analogWrite(RED, LOW);
analogWrite(GREEN, LOW);
analogWrite(BLUE, LOW);
digitalWrite(whiteLedPin, LOW);
Serial.println("Low battery voltage");
analogWrite(rgbLedPin, 255);
Serial.println("Normal battery voltage");
if (accelZ > 15000 && accelY > -2000 && accelY < 2000 && accelX > -2000 && accelX < 2000) {
// Case 1
} else if (accelX < -15000 && accelY > -2000 && accelY < 2000 && accelZ > -2000 && accelZ < 2000) {
// Case 2
currentFunction = 1;
} else if (accelY > 15000 && accelX > -2000 && accelX < 2000 && accelZ > -2000 && accelZ < 2000) {
// Case 3
currentFunction = 2;
} else if (accelX > 15000 && accelY > -2000 && accelY < 2000 && accelZ > -2000 && accelZ < 2000) {
// Case 4
currentFunction = 3;
} else if (accelY < -15000 && accelX > -2000 && accelX < 2000 && accelZ > -2000 && accelZ < 2000) {
// Case 5
currentFunction = 4;
} else if (accelZ < -15000 && accelX > -2000 && accelX < 2000 && accelY > -2000 && accelY < 2000) {
// Case 6
currentFunction = 5;
switch (currentFunction) {
case 0:
digitalWrite(rgbLedPin, LOW);
digitalWrite(whiteLedPin, HIGH);
Serial.println("LED OFF");
case 1:
digitalWrite(rgbLedPin, HIGH);
analogWrite(RED, 0);
analogWrite(GREEN, 255);
analogWrite(BLUE, 255);
Serial.println("Case 2: RED LED ON");
case 2:
analogWrite(RED, 255);
analogWrite(GREEN, 0);
Serial.println("Case 3: GREEN LED ON");
case 3:
analogWrite(BLUE, 0);
Serial.println("Case 4: BLUE LED ON");
case 4:
analogWrite(GREEN, 3);
analogWrite(BLUE, 15);
Serial.println("Case 5: White LED ON");
case 5:
if (millis() - functionStartTime >= warmupDuration) {
digitalWrite(WHITE, LOW);
Serial.println("Case 6: White LED OFF");
if (currentFunction != 5) {
functionStartTime = millis();
delay(1000); // 1초 딜레이
