Here is the unedited code in tags (Please read the “How to use this forum” thread next time):
#include <Wire.h> //°øÅë
#include <Adafruit_Sensor.h> //¿Âµµ,°íµµ
#include <Adafruit_BMP085_U.h>
Adafruit_BMP085_Unified bmp = Adafruit_BMP085_Unified(10085);
const int MPU_addr = 0x68; //ÀÚÀÌ·Î
int16_t AcX, AcY, AcZ, Tmp, GyX, GyY, GyZ;
float dt;
float accel_angle_x, accel_angle_y, accel_angle_z;
float gyro_angle_x, gyro_angle_y, gyro_angle_z;
float filtered_angle_x, filtered_angle_y, filtered_angle_z;
float baseAcX, baseAcY, baseAcZ;
float baseGyX, baseGyY, baseGyZ;
const int driverPin = 10; //Ȑ̉
int led =13;
int j; //¿Âµµ,°íµµ
int arry[200];
initMPU6050(); //ÀÚÀÌ·Î
calibAccelGyro();
initDT();
pinMode(driverPin, OUTPUT); //Ȑ̉
pinMode(led, OUTPUT);
Serial.begin(9600); //¿Âµµ,°íµµ
Serial.println("Pressure Sensor Test"); Serial.println("");
if(!bmp.begin())
Serial.print("Ooops, no BMP085 detected ... Check your wiring or I2C ADDR!");
while(1);
displaySensorDetails();
void displaySensorDetails(void) //¿Âµµ,°íµµ Ãâ·Â
sensor_t sensor;
bmp.getSensor(&sensor);
Serial.println("------------------------------------");
Serial.print ("Sensor: "); Serial.println(sensor.name);
Serial.print ("Driver Ver: "); Serial.println(sensor.version);
Serial.print ("Unique ID: "); Serial.println(sensor.sensor_id);
Serial.print ("Max Value: "); Serial.print(sensor.max_value); Serial.println(" hPa");
Serial.print ("Min Value: "); Serial.print(sensor.min_value); Serial.println(" hPa");
Serial.print ("Resolution: "); Serial.print(sensor.resolution); Serial.println(" hPa");
Serial.println("");
delay(500); //Áö¿¬½Ã°£- 1000=1ÃÊ
readAccelGyro(); //ÀÚÀÌ·Î
calcDT();
calcAccelYPR();
calcGyroYPR();
calcFilteredYPR();
static int cnt;
cnt++;
if(cnt%2 == 0)
SendDataToProcessing();
if(filtered_angle_x==30&&filtered_angle_y==30) //Ȑ̉
delay(3000);
magneticOff();
magneticOn();
int i; //¿Âµµ,°íµµ
j = 0;
for(i=0;i<200;i++)
result();
void initMPU6050() //ÀÚÀÌ·Î ½ÃÀÛ
Wire.begin();
Wire.beginTransmission(MPU_addr);
Wire.write(0x6B);
Wire.write(0);
Wire.endTransmission(true);
void readAccelGyro() //ÀÚÀÌ·Î ÀÔ·Â
Wire.write(0x3B);
Wire.endTransmission(false);
Wire.requestFrom(MPU_addr, 14, true);
AcX = Wire.read() << 8 | Wire.read();
AcY = Wire.read() << 8 | Wire.read();
AcZ = Wire.read() << 8 | Wire.read();
Tmp = Wire.read() << 8 | Wire.read();
GyX = Wire.read() << 8 | Wire.read();
GyY = Wire.read() << 8 | Wire.read();
GyZ = Wire.read() << 8 | Wire.read();
void SendDataToProcessing() //ÀÚÀÌ·Î Ãâ·Â
Serial.print(F(" x = "));
Serial.print(filtered_angle_x, 2);
Serial.print(F(" y = "));
Serial.print(filtered_angle_y, 2);
Serial.print(F(" z = "));
Serial.print(filtered_angle_z, 2);
Serial.println(F(""));
delay(100);
void calibAccelGyro() //ÀÚÀÌ·Î °¡¼Óµµ °è»ê º£À̽º
float sumGyX = 0, sumGyY = 0, sumGyZ = 0;
readAccelGyro();
for(int i=0; i<10; i++){
readAccelGyro();
sumGyX += GyX; sumGyY += GyY; sumGyZ += GyZ;
delay(100);
baseGyX = sumGyX / 10; baseGyY = sumGyY / 10; baseGyZ = sumGyZ / 10;
unsigned long t_now;
unsigned long t_prev;
void initDT()
t_prev = millis();
void calcDT()
t_now = millis();
dt = (t_now - t_prev) / 1000.0;
t_prev = t_now;
//ÀÚÀÌ·Î °¡¼Óµµ °è»ê (YPR)
void calcAccelYPR()
float accel_x, accel_y, accel_z;
float accel_xz, accel_yz;
const float RADIANS_TO_DEGREES = 180/3.14159;
accel_x = AcX - baseAcX;
accel_y = AcY - baseAcY;
accel_z = AcZ + (16384 - baseAcZ);
accel_yz = sqrt(pow(accel_y, 2) + pow(accel_z, 2));
accel_angle_y = atan(-accel_x / accel_yz)*RADIANS_TO_DEGREES;
accel_xz = sqrt(pow(accel_x, 2) + pow(accel_z, 2));
accel_angle_x = atan(accel_y / accel_xz)*RADIANS_TO_DEGREES;
accel_angle_z = 0;
//ÀÚÀÌ·Î ÀÚÀ̷ΰª °è»ê (YPR)
float gyro_x, gyro_y, gyro_z;
void calcGyroYPR()
const float GYROXYZ_TO_DEGREES_PER_SED = 131;
gyro_x = (GyX - baseGyX) / GYROXYZ_TO_DEGREES_PER_SED;
gyro_y = (GyY - baseGyY) / GYROXYZ_TO_DEGREES_PER_SED;
gyro_z = (GyZ - baseGyZ) / GYROXYZ_TO_DEGREES_PER_SED;
gyro_angle_x += gyro_x * dt;
gyro_angle_y += gyro_y * dt;
gyro_angle_z += gyro_z * dt;
void calcFilteredYPR() //ÀÚÀÌ·Î ÇÊÅÍ Àû¿ë°ª °è»ê (YPR)
const float ALPHA = 0.96;
float tmp_angle_x, tmp_angle_y, tmp_angle_z;
tmp_angle_x = filtered_angle_x + gyro_x * dt;
tmp_angle_y = filtered_angle_y + gyro_y * dt;
tmp_angle_z = filtered_angle_z + gyro_z * dt;
filtered_angle_x = ALPHA * tmp_angle_x + (1.0 - ALPHA) * accel_angle_x;
filtered_angle_y = ALPHA * tmp_angle_y + (1.0 - ALPHA) * accel_angle_y;
filtered_angle_z = tmp_angle_z;
void magneticOn() //Ȑ̉
digitalWrite(driverPin, HIGH);
digitalWrite(led, HIGH);
void magneticOff()
digitalWrite(driverPin, LOW);
digitalWrite(led, LOW);
void result() //¿Âµµ,°íµµ ÇÔ¼ö ALL
sensors_event_t event;
bmp.getEvent(&event);
Serial.print("Pressure: ");
Serial.print(event.pressure);
delay(100);
float temperature;
bmp.getTemperature(&temperature);
Serial.print("Temperature: ");
Serial.print(temperature);
Serial.println(" C");
delay(100);
float seaLevelPressure = SENSORS_PRESSURE_SEALEVELHPA;
arry[j]=bmp.pressureToAltitude(seaLevelPressure,event.pressure);
if(arry[j]-arry[0]>=0)
Serial.print("Altitude: ");
Serial.print(arry[j]-arry[0]);
Serial.println(" m");
Serial.println(j);
Serial.println("");
Serial.println("default");
Serial.println(j);
Serial.println("");
j++;
delay(100);
