So i am trying to get this new 6dof gyro and acceletomiter working, but i have tried everything, and it is not working. my final stop was the i2cdev library buy jeff, and it is even worse. I does not print normal caracters i get this(using his MPU6050_DMP6 example sketch on the uno)
ÛðÙT·DWá÷
and when i enter a letter this happens
ÛðÙT·DWá÷MÌÖkO`nþ
when i tried using his MPU6050_raw example this happens
ààüàààààü¨¬ ± -!-14¤¥5%
µ$%¥¡0 ´¥Ç%µ!0 4¤!¡!%5´¥
and it keeps printing nonstop.
so i decided to try the examples from the arduino webside on the mpu6050 i wont put the code here since it is to long but here is a link to it (Arduino Playground - MPU-6050 it is the last example down roughly 900 lines)
here is what i got:
MPU-6050
Read accel, temp and gyro, error = 0
accel x,y,z: -164, 4758, 17040
temperature: 30.865 degrees Celsius
gyro x,y,z : 343, 361, -143,
MPU-6050
accel x,y,z: 16732, 746, -2242
temperature: 30.847 degrees Celsius
gyro x,y,z : 874, -131, -363,
MPU-6050
accel x,y,z: 4510, -7420, 13774
gyro x,y,z : 1822, 2928, 8526,
MPU-6050
accel x,y,z: -6016, -1678, -16304
temperature: 31.018 degrees Celsius
gyro x,y,z : 32767, -21928, -20069,
MPU-6050
accel x,y,z: 3486, 10330, -5702
temperature: 30.894 degrees Celsius
gyro x,y,z : 32767, -31308, -15464,
MPU-6050
accel x,y,z: 3308, -9292, 6200
gyro x,y,z : 3166, -8144, 27748,
MPU-6050
accel x,y,z: -320, -13024, 11298
temperature: 30.776 degrees Celsius
gyro x,y,z : 376, 462, -143,
MPU-6050
accel x,y,z: -484, -13260, 10908
temperature: 30.771 degrees Celsius
gyro x,y,z : 342, 258, -319,
as you can see when i move it the numbers become incredibly huge(at least the temperature is right). so i then decided to give the other example roughly 40 lines long on the same page. and my out come was as strange:
[code] AcX = -682 | AcY = 2178 | AcZ = 17698 | Tmp = 27.55 | GyX = 473 | GyY = 234 | GyZ = -219
AcX = -598 | AcY = 2224 | AcZ = 17580 | Tmp = 27.57 | GyX = 550 | GyY = -59 | GyZ = -680
AcX = -756 | AcY = 2196 | AcZ = 17680 | Tmp = 27.57 | GyX = 375 | GyY = 272 | GyZ = -164
AcX = 5578 | AcY = 13118 | AcZ = 13424 | Tmp = 27.57 | GyX = 32767 | GyY = -13348 | GyZ = -1000
AcX = 1846 | AcY = 14718 | AcZ = 7596 | Tmp = 27.55 | GyX = 875 | GyY = 362 | GyZ = -32
AcX = 2216 | AcY = 14504 | AcZ = 6930 | Tmp = 27.57 | GyX = 630 | GyY = 800 | GyZ = -1125
AcX = 2390 | AcY = 14968 | AcZ = 7338 | Tmp = 27.57 | GyX = 568 | GyY = 241 | GyZ = -92
AcX = 2338 | AcY = 14928 | AcZ = 7486 | Tmp = 27.54 | GyX = 561 | GyY = 158 | GyZ = -396
AcX = 2698 | AcY = 15038 | AcZ = 7466 | Tmp = 27.55 | GyX = 1231 | GyY = 341 | GyZ = -252
AcX = 7560 | AcY = 12958 | AcZ = 11980 | Tmp = 27.55 | GyX = -32768 | GyY = 19048 | GyZ = 7243
AcX = -106 | AcY = 876 | AcZ = 16868 | Tmp = 27.53 | GyX = 890 | GyY = -442 | GyZ = -1959
AcX = -114 | AcY = 1390 | AcZ = 17586 | Tmp = 27.55 | GyX = 1534 | GyY = -281 | GyZ = -665
it is the same issue as before i get really huge and odd numbers. i don't think this is deg/s nor deg/minute. can anyone assist?[/code]
