MPU 6050 sending gibberish data to the serial monitor
Hi there, I am making a flight computer for an upcoming rocket and am using an MPU 6050 as my IMU. When I run the code, the serial monitor shows some gibberish letters. I have the required libraries too. The board I am using is an Arduino Nano. Please help. Thanks in advance.
The code -
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
THE SOFTWARE.
// I2Cdev and MPU6050 must be installed as libraries, or else the .cpp/.h files
// for both classes must be in the include path of your project
#include "I2Cdev.h"
#include "MPU6050.h"
// Arduino Wire library is required if I2Cdev I2CDEV_ARDUINO_WIRE implementation
// is used in I2Cdev.h
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
#include "Wire.h"
#endif
// class default I2C address is 0x68
// specific I2C addresses may be passed as a parameter here
// AD0 low = 0x68 (default for InvenSense evaluation board)
// AD0 high = 0x69
MPU6050 accelgyro;
//MPU6050 accelgyro(0x69); // <-- use for AD0 high
int16_t ax, ay, az;
int16_t gx, gy, gz;
// uncomment "OUTPUT_READABLE_ACCELGYRO" if you want to see a tab-separated
// list of the accel X/Y/Z and then gyro X/Y/Z values in decimal. Easy to read,
// not so easy to parse, and slow(er) over UART.
#define OUTPUT_READABLE_ACCELGYRO
// uncomment "OUTPUT_BINARY_ACCELGYRO" to send all 6 axes of data as 16-bit
// binary, one right after the other. This is very fast (as fast as possible
// without compression or data loss), and easy to parse, but impossible to read
// for a human.
//#define OUTPUT_BINARY_ACCELGYRO
#define LED_PIN 13
bool blinkState = false;
// join I2C bus (I2Cdev library doesn't do this automatically)
Wire.begin();
#elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
Fastwire::setup(400, true);
#endif
// initialize serial communication
// (38400 chosen because it works as well at 8MHz as it does at 16MHz, but
// it's really up to you depending on your project)
Serial.begin(38400);
// initialize device
Serial.println("Initializing I2C devices...");
accelgyro.initialize();
// verify connection
Serial.println("Testing device connections...");
Serial.println(accelgyro.testConnection() ? "MPU6050 connection successful" : "MPU6050 connection failed");
// use the code below to change accel/gyro offset values
Serial.println("Updating internal sensor offsets...");
// -76	-2359	1688	0	0	0
Serial.print(accelgyro.getXAccelOffset()); Serial.print("\t"); // -76
Serial.print(accelgyro.getYAccelOffset()); Serial.print("\t"); // -2359
Serial.print(accelgyro.getZAccelOffset()); Serial.print("\t"); // 1688
Serial.print(accelgyro.getXGyroOffset()); Serial.print("\t"); // 0
Serial.print(accelgyro.getYGyroOffset()); Serial.print("\t"); // 0
Serial.print(accelgyro.getZGyroOffset()); Serial.print("\t"); // 0
Serial.print("\n");
accelgyro.setXGyroOffset(220);
accelgyro.setYGyroOffset(76);
accelgyro.setZGyroOffset(-85);
Serial.print("\n");
// configure Arduino LED for
pinMode(LED_PIN, OUTPUT);
// read raw accel/gyro measurements from device
accelgyro.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
// these methods (and a few others) are also available
//accelgyro.getAcceleration(&ax, &ay, &az);
//accelgyro.getRotation(&gx, &gy, &gz);
#ifdef OUTPUT_READABLE_ACCELGYRO
    // display tab-separated accel/gyro x/y/z values
    Serial.print("a/g:\t");
    Serial.print(ax); Serial.print("\t");
    Serial.print(ay); Serial.print("\t");
    Serial.print(az); Serial.print("\t");
    Serial.print(gx); Serial.print("\t");
    Serial.print(gy); Serial.print("\t");
    Serial.println(gz);
#endif
#ifdef OUTPUT_BINARY_ACCELGYRO
    Serial.write((uint8_t)(ax >> 8)); Serial.write((uint8_t)(ax & 0xFF));
    Serial.write((uint8_t)(ay >> 8)); Serial.write((uint8_t)(ay & 0xFF));
    Serial.write((uint8_t)(az >> 8)); Serial.write((uint8_t)(az & 0xFF));
    Serial.write((uint8_t)(gx >> 8)); Serial.write((uint8_t)(gx & 0xFF));
    Serial.write((uint8_t)(gy >> 8)); Serial.write((uint8_t)(gy & 0xFF));
    Serial.write((uint8_t)(gz >> 8)); Serial.write((uint8_t)(gz & 0xFF));
#endif
// blink LED to indicate activity
blinkState = !blinkState;
digitalWrite(LED_PIN, blinkState);
OUTPUT -
Welcome to the forum.
Please read the post at the start of any forum , entitled "How to use this Forum".
OR
https://forum.arduino.cc/index.php?topic=712198.0
Have you tried the example codes with the Library to check your connections.
Can you please post a circuit diagram please?
Thanks.. Tom... :grinning: :+1: :coffee: :australia:
Have you set the baud rate on your monitor to 38400 ?
no, it is at 9600
Yes, i have but am facing the issue even then
Do you get any readable text on the monitor when you open it?
Like "Initializing I2C devices..."
Hi, no, i get random symbols
I know that I have all the libraries and have even tried this with other unos and mpu's but it still shows data like that
The system failed in that first 2 lines. - Nothing to do with the "library" yet. You can try put a delay(2000)? before continue;
The Serial port was good because the IDE can upload.
The only thing left to double check is the synchronization set up by the code "38400" and the receiving ends; the monitor.
Hope this helps.
I tried this but it is giving the error - 'Serial' does not name a type
and ide is pink-lining the line - Serial.println(accelgyro.testConnection() ? "MPU6050 connection successful" : "MPU6050 connection failed");
2 scenarios after put in a delay:
  • If the serial monitor shows "Initializing I2C devices..." Then Either the MPU6050 board or the library or both are up to no good
  • Otherwise the communication bw the UNO and the monitor need to be checked.
Hope it hepls.
No, the serial monitor doesn't show "Initializing I2C devices....".
So it's the second case, but if I upload the blink program, the Arduino responds perfectly fine.
Obviously the 38400 and the setup at the monitor monitor side doesn't synchronize.
So..., what shud i do
New sketch:
To play with variable values of the serial begin . . . Until you can see some meaningful things on the monitor.
k, i will get back in 10 mins
Make sure you have the 050 unplugged at least the 5V line
Sorry, what do you mean by 050
THE MPU6050.
if the unplugging make the system work then it is no-good-- drawing too much current
