Hello Guys,
I have an issue with my MPU-6050.
I work with the Library from Jeff Rowberg - should be famous i think.
Now i tried the DMP-example with READABLE_QUATERNION. The Z-Axis works fine and without latency. But the X/Y - Axis is very slow and cant be used for my project. Is there a way to make it latency-free?
// if programming failed, don't try to do anything
if (!dmpReady) return;
// wait for MPU interrupt or extra packet(s) available
while (!mpuInterrupt && fifoCount < packetSize) {
// other program behavior stuff here
// if you are really paranoid you can frequently test in between other
// stuff to see if mpuInterrupt is true, and if so, "break;" from the
// while() loop to immediately process the MPU data
// reset interrupt flag and get INT_STATUS byte
mpuInterrupt = false;
mpuIntStatus = mpu.getIntStatus();
// get current FIFO count
fifoCount = mpu.getFIFOCount();
// check for overflow (this should never happen unless our code is too inefficient)
if ((mpuIntStatus & 0x10) || fifoCount == 1024) {
// reset so we can continue cleanly
mpu.resetFIFO();
Serial.println(F("FIFO overflow!"));
// otherwise, check for DMP data ready interrupt (this should happen frequently)
} else if (mpuIntStatus & 0x02) {
// wait for correct available data length, should be a VERY short wait
while (fifoCount < packetSize) fifoCount = mpu.getFIFOCount();
// read a packet from FIFO
mpu.getFIFOBytes(fifoBuffer, packetSize);
// track FIFO count here in case there is > 1 packet available
// (this lets us immediately read more without waiting for an interrupt)
fifoCount -= packetSize;
#ifdef OUTPUT_READABLE_QUATERNION
// display quaternion values in easy matrix form: w x y z
mpu.dmpGetQuaternion(&q, fifoBuffer);
Serial.print("quat\t");
Serial.print(q.w);
Serial.print("\t");
Serial.print(q.x, 6);
Serial.print("\t");
Serial.print(q.y, 6);
Serial.print("\t");
Serial.println(q.z, 6);
#endif
I recommend to RTIMUlib for Arduino. It is state of the art and works with that sensor.
Okay, i threw a look on this lib. Well it doesnt worked for me directly. I would have to study this librarie to deal with it.
it would be nice to use the J.Rowberg lib.
Any other ideas?
Okay I found the solution:
If i delete the offsets in my code, there is no latency. But also, the sensor values don't start at '0'.
So, now i need no latency, and a '0'-value at the start
Does anyone of you have an idea of this issue? Maybe the offsets to a low-perfomance calculating, and so the value are calculated very slow?
Hey Guys,
I discovered a strange behavior for my issue. If i use all Offsets without the 'setZAccelOffset', everything is fine and works smoothly (no latency). But if I insert the setZAccelOffset with my Value-Offset (4951) it starts delaying and its getting worse.
Also, if i use a low offsetvalue for the Z-Axis, such as 10 or 100, it still works fine.
So if the value gets higher - the delay and the craziness of this behaviour also increases.
What can I do now? I need this Offset, but I can't accept this delay. Do I need a new sensor maybe? Is this Offset-Value (4951) too high? What do you guys have for your offsets?
thank you.
What you could do is post all of your code, because I'm not seeing anything about "offsets" in what you have already posted...
// === INITIAL SETUP ===
// join I2C bus (I2Cdev library doesn't do this automatically)
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
Wire.begin();
TWBR = 24; // 400kHz I2C clock (200kHz if CPU is 8MHz)
#elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
Fastwire::setup(400, true);
#endif
// initialize serial communication
// (115200 chosen because it is required for Teapot Demo output, but it's
// really up to you depending on your project)
while (!Serial); // wait for Leonardo enumeration, others continue immediately
// NOTE: 8MHz or slower host processors, like the Teensy @ 3.3v or Ardunio
// Pro Mini running at 3.3v, cannot handle this baud rate reliably due to
// the baud timing being too misaligned with processor ticks. You must use
// 38400 or slower in these cases, or use some kind of external separate
// crystal solution for the UART timer.
// initialize device
Serial.println(F("Initializing I2C devices..."));
mpu.initialize();
// verify connection
Serial.println(F("Testing device connections..."));
Serial.println(mpu.testConnection() ? F("MPU6050 connection successful") : F("MPU6050 connection failed"));
// wait for ready
Serial.println(F("\nSend any character to begin DMP programming and demo: "));
while (Serial.available() && Serial.read()); // empty buffer
while (!Serial.available()); // wait for data
while (Serial.available() && Serial.read()); // empty buffer again
// load and configure the DMP
Serial.println(F("Initializing DMP..."));
devStatus = mpu.dmpInitialize();
// supply your own gyro offsets here, scaled for min sensitivity
mpu.setXGyroOffset(-36);
mpu.setYGyroOffset(-85);
mpu.setZGyroOffset(-3);
//mpu.setZAccelOffset(4951); //if i activate this offset, there is the delay
mpu.setYAccelOffset(1072);
mpu.setXAccelOffset(-2340);
// make sure it worked (returns 0 if so)
if (devStatus == 0) {
// turn on the DMP, now that it's ready
Serial.println(F("Enabling DMP..."));
mpu.setDMPEnabled(true);
// enable Arduino interrupt detection
Serial.println(F("Enabling interrupt detection (Arduino external interrupt 0)..."));
attachInterrupt(0, dmpDataReady, RISING);
// set our DMP Ready flag so the main loop() function knows it's okay to use it
Serial.println(F("DMP ready! Waiting for first interrupt..."));
dmpReady = true;
// get expected DMP packet size for later comparison
packetSize = mpu.dmpGetFIFOPacketSize();
// ERROR!
// 1 = initial memory load failed
// 2 = DMP configuration updates failed
// (if it's going to break, usually the code will be 1)
Serial.print(F("DMP Initialization failed (code "));
Serial.print(devStatus);
Serial.println(F(")"));
// configure LED for output
pinMode(LED_PIN, OUTPUT);
// === MAIN PROGRAM LOOP ===
mpu.resetFIFO();
Serial.print(q.w);
Serial.print("\t");
Serial.print(q.x);
Serial.print("\t");
Serial.print(q.y);
Serial.print("\t");
Serial.println(q.z);
#endif
// blink LED to indicate activity
blinkState = !blinkState;
digitalWrite(LED_PIN, blinkState);
