Mpu 6050 with arduino nano data reset beacuse of delay.
Hi guys,
i'm new to arduino and really struggling with the delay function. I'm using the mpu 6050 with arduino nano to create an accelerator. I've used the 3 pins rgb led and connected them and used the data pin 13. On the basis of the data received from sensor the arduino lights them up. On stationary the leds light up in red and when there is acceleration a happy face pops up. The issue is i cant figure out how to stop the delay as it rests the data and the lights turn back to red for a sec and then converts back to the smiley sign that is created.
Here is the code.
// MPU-6050 Short Example Sketch
// By Arduino User JohnChi
// August 17, 2014
// Public Domain
#include<Wire.h>
const int MPU_addr=0x68; // I2C address of the MPU-6050
int16_t AcY;
int OldAcY;
void setup(){
Wire.begin();
Wire.beginTransmission(MPU_addr);
Wire.write(0x6B); // PWR_MGMT_1 register
Wire.write(0); // set to zero (wakes up the MPU-6050)
Wire.endTransmission(true);
OldAcY =AcY;
Wire.write(0x3B); // starting with register 0x3B (ACCEL_XOUT_H)
Wire.endTransmission(false);
Wire.requestFrom(MPU_addr,14,true); // request a total of 14 registers
// AcX=Wire.read()<<8|Wire.read(); // 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
AcY=Wire.read()<<8|Wire.read(); // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
// AcZ=Wire.read()<<8|Wire.read(); // 0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
// Tmp=Wire.read()<<8|Wire.read(); // 0x41 (TEMP_OUT_H) & 0x42 (TEMP_OUT_L)
//GyX=Wire.read()<<8|Wire.read(); // 0x43 (GYRO_XOUT_H) & 0x44 (GYRO_XOUT_L)
//GyY=Wire.read()<<8|Wire.read(); // 0x45 (GYRO_YOUT_H) & 0x46 (GYRO_YOUT_L)
//GyZ=Wire.read()<<8|Wire.read(); // 0x47 (GYRO_ZOUT_H) & 0x48 (GYRO_ZOUT_L)
//Serial.print("AcX = "); Serial.print(AcX);
//Serial.print(" | AcY = "); Serial.print(AcY);
//Serial.print(" | AcZ = "); Serial.print(AcZ);
//Serial.print(" | Tmp = "); Serial.print(Tmp/340.00+36.53); //equation for temperature in degrees C from datasheet
//Serial.print(" | GyX = "); Serial.print(GyX);
//Serial.print(" | GyY = "); Serial.print(GyY);
//Serial.print(" | GyZ = "); Serial.println(GyZ);
Serial.println( (((AcY-OldAcY)/1000)>1) );
if(((AcY-OldAcY)/1000)>1)
{digitalWrite(13, HIGH);delay(1600);}
if (((AcY-OldAcY)/1000)<1)
{digitalWrite(13, LOW);}
delay(200);
Why did you comment out some lines? (you request a total of 14 registers and don't read them all...)
if you don't want any delay, then remove delay(200);...
Please correct your post above and add code tags around your code:
[code]`` [color=blue]// your code is here[/color] ``[/code].
It should look like this:// your code is here
(Also press ctrl-T (PC) or cmd-T (Mac) in the IDE before copying to indent your code properly)
