MPU-6050
Hi all, I got a MPU-6050 from invensense from the guys at drotek http://www.drotek.fr/shop/en/42-mpu6050-gyro-accelerometer.html and I haven't been able to get anything out of that chip, not even an address with this I2C scanner http://todbot.com/arduino/sketches/I2CScanner/I2CScanner.pde. I have set it up using the sparkfun logic level converter http://www.sparkfun.com/products/8745, using both TX pin pairs for sda and scl. The level converter has built in pull-up resistors and I can measure 5v on the sda and scl pins on the arduino. The MPU is powered by the arduino 3.3v pin. Aside from a faulty/fried device, what could cause me not to see the chip at all on the i2c bus? I am new to all this and any help is very much appreciated, thank you.
Beginner`s mistake! For future reference, I was able to make my setup work by using shorter wires that have lower gauge.
Oh yes? How short / thick do the wires have to be? And how long did you have them in the first place?
Considering buying the MPU-6050 drotek board myself, so it's good to hear you got it running. Found some other reports online, that they actually send it out with a wrong chip mounted on it: http://www.varesano.net/blog/fabio/mpu6050-finally
Hi, yes I saw those reports too so I made sure I checked the chip when I got it. Originally I was using the sparkfun jumper wires that come with the arduino kit they sell http://www.sparkfun.com/products/11026, I had no idea this could make a difference. Now it`s hooked up using 22 gauge wire http://www.robotshop.com/ca/elenco-22-gauge-green-25-ft-1.html. As for the length of the cable, the setup looks like this now (bit messy)
Good luck with your project!
Maybe one of the jumper wires was faulty. Hard to believe that they would make a big difference.
I was more anticipating that you had first used a meter-long wire or so .. :)
Hi, I would like to buy a "MPU-6050 Module 3 Axis Gyroscope+?Accelerome?ter" but I don't understand what is the different between this
http://i.ebayimg.com/t/MPU-6050-Module-3-Axis-Gyroscope-Accelerometer-Module-Arduino-DIY-/00/s/NjEzWDY2Mg==/$(KGrHqFHJCsE-nCC9g)KBPqyl+QOo!~~60_35.JPG
and this
http://inmotion.pt/blog/wp-content/uploads/2012/05/Triple_Axis_Accelerometer_Gyro_Breakout_MPU_6050.jpg
I have seen that there are 8pins on the first and 10pins on the second... Can you help me?
Thaks!!!
Hello Woodstock,
You started a new question on an old post. For this you could better start a new post. I have made a page for the MPU-6050 : http://arduino.cc/playground/Main/MPU-6050
You have to check the datasheet, to check which the signal lines on the pins of the boards.
Sorry for my late reply…
Ok Krodal, thank you for the link.
Hello everyone! I,m from Russia and sorry for english at first! ) I have some problems with my MPU6050 (Sparkfun edition) htts://www.sparkfun.com/products/11028 I connect SCL on the board to A5 and SDA to A4 inputs with pull-up resistors (10k or 4,7k) on Ardruino MEGA. GND to Ground & VDD to 3,3V. But I2C Scanner didn't find my MPU6050 board. What i do wrong????!!!! Please Help ME! ((ß
You have a Arduino Mega : http://arduino.cc/en/Main/ArduinoBoardMega/ The SDA and SCL are pin 20 and 21.
Krodal: You have a Arduino Mega : http://arduino.cc/en/Main/ArduinoBoardMega/ The SDA and SCL are pin 20 and 21.
Thank you!! ))) I forgot it! But on 20-21 SDA/SCL don't work too!!! ((( Maybe i must change some options more on mega???
But i try to catch I2C signal from ASCL / ASDA pins on the board, and when i try it - program immediately hangs (stopped on "Scanning" step)... What does matter maybe??
Is this your sensor board : https://www.sparkfun.com/products/11028
If the I2C can’t continue, perhaps something is keeping the line low. You might have mixed up the SDA and SCL, or the pull-up resistors are missing, or you use very long wires, or you accidently used ASCL and ASDA (which are for a second sub-i2c bus), or the voltage is wrong, or de sensor is damaged, or something else.
Hi please, can someone post an image with the links between MPU6050 (htts://www.sparkfun.com/products/11028) and arduino?? Because I don't understand how and if I must add the 4.7K resistors. I read some post regard MPU6050 but someone use the resistors and other don't... example in this post --> arduino.cc/forum/index.php/topic,103408.0.html
Thank you so much!
The first picture in this page shows how : http://arduino.cc/playground/Main/I2CBi-directionalLevelShifter
But the Sparkfun breakout board has already 10k pull-up resistors. You don't really need extra pull-up resistors, but 4k7 is better than 10k. So you could add two 10k pull-up resistors (10k parallel 10k becomes 5k). But that's just an improvement. The breakout board should work if those 10k on the breakout board are soldered properly.
Hello everyone,
I found this thread because I use the MPU 6050 and a Arduino Nano. Therefore I use Jeff Rowbergs I2Ccdevlib for handling data of the MPU6050.
Currently I'm using this sketch: https://github.com/jrowberg/i2cdevlib/blob/master/Arduino/MPU6050/examples/MPU6050_DMP6/MPU6050_DMP6.ino
In the first 20 seconds after startig, the sensor values are floating a little bit. After that time the sensor values are nearly constant. I want to show the values on a serial monitor only if they are constant (after the 20 seconds). Which program codes do I have to keep in the void loop function?
I want this behaviour [PSEUDOCODE]
WHILE (SensorValuesCalibrating) { //DO NOTHING }
// NOW SENSOR VALUES ARE CONSTANT // DO OTHER STUFF
