MPU 6050_DMP6 help
Hello all,
I am trying to create my own library from the MPU6050_DMP6 code. What I am trying to do is display the X value from the MPU 6050. I am fully aware that I can easilly do it from the MPU6050_DMP6 code in the void loop. I am new to arduino and I have been working on this all weekend with zero luck. Can someone please take a look at my code below , and help me to understand where I went wrong? Thank you.
#include "I2Cdev.h"
#include "MPU6050.h"
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
MPU6050 mpu;
#include "Wire.h"
#endif
float ypr[3];           // [yaw, pitch, roll]   yaw/pitch/roll container and gravity vector
 int Xaxis;
    Wire.begin();
    Serial.println("Initialize MPU");
    mpu.initialize();
    Serial.println(mpu.testConnection() ? "Connected" : "Connection failed");
    mpu.setDMPEnabled(true);
   Xaxis= ypr[2] * 180/M_PI;
   Serial.println(Xaxis);
It might be the way this array is defined: here is an example from the PLAYGROUND:
int ledPins[] = {  2, 7, 4, 6, 5, 3 };       // an array of pin numbers to which LEDs are attached
which leads me to believe your array should be :
    float ypr[] = {yaw, pitch, roll};
but I could be wrong.
Thanks for the reply, and help but that didnt work. Does anyone else have any suggestion?
