Hello
I'm having an issue when trying to set the 0x1C accel. register sensitivity.
2g works fine with 0x00
When I set 4g with 0x01 i still get 2g raw values
8g works fine with 0x10
When I set 16g with 0x11 i still get 8g raw values
Do you think my sensor is bad or am I missing something?
Seems to me its ignoring the 3rd bit.
Here is my code with 16g config:
#include <Wire.h>
long X, Y, Z;
float gX, gY, gZ;
Wire.begin();
setupsensor();
recordG();
printData();
delay(100);
void setupsensor() {
Wire.beginTransmission(0b1101001); // AD0 High
Wire.write(0x6B); // power management
Wire.write(0b00000000); //Setting sleep to 0
Wire.endTransmission();
Wire.write(0x1C); // sensitivity configuration
Wire.write(0x11); // 0x00 2g at 16384LSB/g, 0x01 4g at 8192LSB/g, 0x10 8g at 4,096LSB/g, 0x11 16g at 2048LSB/g
void recordG() {
Wire.write(0x3B); // Accel Read
Wire.requestFrom(0b1101001,6); //request Accel registers (3B - 40)
while(Wire.available() < 6);
X = Wire.read()<<8|Wire.read();
Y = Wire.read()<<8|Wire.read();
Z = Wire.read()<<8|Wire.read();
CalcG();
void CalcG() {
gX = X / 2048.0;
gY = Y / 2048.0;
gZ = Z / 2048.0;
void printData() {
Serial.print ("X=");
Serial.print (X);
Serial.print (" Y=");
Serial.print (Y);
Serial.print (" Z=");
Serial.println (Z);
Serial.print ("gX=");
Serial.print (gX);
Serial.print (" gY=");
Serial.print (gY);
Serial.print (" gZ=");
Serial.println (gZ);
And this is what I get:
16:14:40.278 -> X=497 Y=398 Z=3317
16:14:40.312 -> gX=0.24 gY=0.19 gZ=1.62
When you read and print out the register, after modifying the register, what value do you get vs value expected?
Here is the code I use to change the accel register:
int myMPU9250::setAccelRange( int range )
SPI_Err = 0;
if ( ACCEL_RANGE_2G == range )
// setting the accel range to 2G
SPI_Err = _spi.fWriteSPIdata8bits( ACCEL_CONFIG, ACCEL_FS_SEL_2G );
vTaskDelay(1);
_accelScaleFactor = (G * 2.0f) / AtoDscaleFactor; // setting the accel scale to 2G
return SPI_Err;
if ( ACCEL_RANGE_4G == range )
// setting the accel range to 4G
SPI_Err = _spi.fWriteSPIdata8bits(ACCEL_CONFIG, ACCEL_FS_SEL_4G);
vTaskDelay(1);
_accelScaleFactor = (G * 4.0f) / AtoDscaleFactor; // setting the accel scale to 4G
return SPI_Err;
if ( ACCEL_RANGE_8G == range )
// setting the accel range to 8G
SPI_Err = _spi.fWriteSPIdata8bits( ACCEL_CONFIG, ACCEL_FS_SEL_8G );
vTaskDelay(1);
_accelScaleFactor = (G * 8.0f) / AtoDscaleFactor; // setting the accel scale to 8G
return SPI_Err;
if ( ACCEL_RANGE_16G == range )
// setting the accel range to 16G
SPI_Err = _spi.fWriteSPIdata8bits( ACCEL_CONFIG, ACCEL_FS_SEL_16G );
vTaskDelay(1);
_accelScaleFactor = (G * 16.0f) / AtoDscaleFactor; // setting the accel scale to 16G
return SPI_Err;
} //int myMPU9250::setAccelRange( int range )
Works fine for each setting.
Are you adjusting the scale factor with each setting change?
I have found that, for some unknown reason, when reading a group of registers of the MPU9250 that the first 16bits will, from time to time, not read out correctly. A, 100%, solution has been to read the register previous to the ones I want and, during data processing, ignore the first 16 bits.
int myMPU9250::getAdata()
SPI_Err = 0;
SPI_Err = _spi.fReadSPI( 8 , 0X3A | SPI_READ );
if ( SPI_Err == 0 )
x_Araw.x = 0.0;
x_Araw.y = 0.0;
x_Araw.z = 0.0;
// transform
x_Araw.y = ((float)(int16_t)(((int16_t)_spi.get_rxData8bit(2) << 8) | _spi.get_rxData8bit(3)));
x_Araw.x = ((float)(int16_t)(((int16_t)_spi.get_rxData8bit(4) << 8) | _spi.get_rxData8bit(5)));
x_Araw.z = ((float)(int16_t)(((int16_t)_spi.get_rxData8bit(6) << 8) | _spi.get_rxData8bit(7)));
x_Araw.z *= -1;
// scale and bias
x_Ascaled.x = ( (x_Araw.x * _accelScaleFactor) - x_Abias.x ) * x_ASF.x;
x_Ascaled.y = ( (x_Araw.y * _accelScaleFactor) - x_Abias.y ) * x_ASF.y;
x_Ascaled.z = ( (x_Araw.z * _accelScaleFactor) - x_Abias.z ) * x_ASF.z;
// reads one address previous to the accelerometer data
// found that from time to time only positive values returned if
// desired register was read directly
return SPI_Err;
Hi Idahowalker
Thank you, You pointed me to the right direction, after reading the register I found that the values were not what they were supposed to be.
I found the error in my config, I was setting incorrect hex value.
Here are correct values
Binary:
2g = 0b00000000
4g = 0b00001000
8g = 0b00010000
16g = 0b00011000
Hex:
2g = 0x00
4g = 0x8
8g = 0x10
16g = 0x18
And here is the correct config for 16g sensitivity:
Wire.write(0b00011000); // 0x00 2g at 16384LSB/g, 0x8 4g at 8192LSB/g, 0x10 8g at 4,096LSB/g, 0x18 16g at 2048LSB/g
Anyways Thanks for the config, I haven't run into your issue but I'll look out for it..
