All I want to do is obtain the raw data from accelerometer, gyroscope and magnetometer from the sensor so I can record it/process it/etc in matlab.... However I am having a great deal of trouble knowing how to configure the code.. I tried using the arduino library by Kris Winer, but every time I try and run the code I get this error:
MPU9250 I AM FF I should be 71
Could not connect to MPU9250: 0xFF
I also tried running the code on this site here:
and with that, I am getting 7 columns of data on the serial monitor, however, none of them change except the iteration column (the first column)...
If someone could please help me, I would greatly appreciate it. Thank you so much.
Make sure you have the correct V, G & I2C connections between the 2 boards and that the correct pin #'s are in the code. Also, make sure voltage levels are correct for power AND signals.
JohnnyF7:
Hey, just got myself the MPU-9250 and was getting the same error. It's really easy to fix and the problem is that the instructions indicate to plug the SDA and SCL pins of the chip to the A4 and A5 of the Arduino board. This will not work on the Arduino UNO as it already has some pins dedicated to the SDA and SCL. This pins are next to the ground after the digital pin 13. Once connected to this pins everything should work as intended
