I am testing two different methods to read raw acceleration data.
- a function reads individual register and the returned value gets saved in a buffer in main loop.
#define MPU_REG_ACCEL_XOUT_H 0x3B
#define MPU_REG_ACCEL_XOUT_L 0x3C
#define MPU_REG_ACCEL_YOUT_H 0x3D
#define MPU_REG_ACCEL_YOUT_L 0x3E
#define MPU_REG_ACCEL_ZOUT_H 0x3F
#define MPU_REG_ACCEL_ZOUT_L 0x40
buf[0] = mpu_read(MPU_REG_ACCEL_XOUT_H);
buf[1] = mpu_read(MPU_REG_ACCEL_XOUT_L);
buf[2] = mpu_read(MPU_REG_ACCEL_YOUT_H);
buf[3] = mpu_read(MPU_REG_ACCEL_YOUT_L);
buf[4] = mpu_read(MPU_REG_ACCEL_ZOUT_H);
buf[5] = mpu_read(MPU_REG_ACCEL_ZOUT_L);
accel_temp[0] = (buf[0]<<8|buf[1]);
accel_temp[1] = (buf[2]<<8|buf[3]);
accel_temp[2] = (buf[4]<<8|buf[5]);
char mpu_read(char addr)
digitalWrite(MPU_CS,LOW);
MPU_SPI.transfer(0x80|addr);
char ret = MPU_SPI.transfer(0X00);
digitalWrite(MPU_CS,HIGH);
return ret;
- a function reads all the accelerometer registers and save the values in a buffer. The function returns the buffer to the main function.
mpu_read_bytes(MPU_REG_ACCEL_XOUT_H, &buf[0], 6);
int16_t accel_temp[3];
void mpu_read_bytes(char addr, uint8_t *buf, unsigned n)
digitalWrite(MPU_CS, LOW);
for(int i = 0; i< n; i++)
char reg = addr+i;
MPU_SPI.transfer(0x80|reg);
char ret = MPU_SPI.transfer(0x00);
buf = ret;
- digitalWrite(MPU_CS, HIGH);*
I believe accel_temp[] values for both methods should be the same.
However, they are not.
accel_temp[0] are the same.
accel_temp[1] of the first method is the same as accel_temp[2] of the second method.
accel_temp[2] of the first method is the same as accel_temp[1] of the second method.
Can you suggest why it happens and how to fix the problem?
Thanks
