MPU-9250
Hi all,
I have found the code below on the web for mpu9250 but I dont know how to calculate degrees from magnetometer.
I need your help.
thanks
#include <Wire.h>
#include <TimerOne.h>
#define    MPU9250_ADDRESS            0x68
#define    MAG_ADDRESS                0x0C
#define    GYRO_FULL_SCALE_250_DPS    0x00
#define    GYRO_FULL_SCALE_500_DPS    0x08
#define    GYRO_FULL_SCALE_1000_DPS   0x10
#define    GYRO_FULL_SCALE_2000_DPS   0x18
#define    ACC_FULL_SCALE_2_G        0x00
#define    ACC_FULL_SCALE_4_G        0x08
#define    ACC_FULL_SCALE_8_G        0x10
#define    ACC_FULL_SCALE_16_G       0x18
// This function read Nbytes bytes from I2C device at address Address.
// Put read bytes starting at register Register in the Data array.
void I2Cread(uint8_t Address, uint8_t Register, uint8_t Nbytes, uint8_t* Data)
  // Set register address
  Wire.beginTransmission(Address);
  Wire.write(Register);
  Wire.endTransmission();
  // Read Nbytes
  Wire.requestFrom(Address, Nbytes);
  uint8_t index=0;
  while (Wire.available())
    Data[index++]=Wire.read();
// Write a byte (Data) in device (Address) at register (Register)
void I2CwriteByte(uint8_t Address, uint8_t Register, uint8_t Data)
  Wire.write(Data);
// Initial time
long int ti;
volatile bool intFlag=false;
// Initializations
  // Arduino initializations
  Wire.begin();
  // Set accelerometers low pass filter at 5Hz
  I2CwriteByte(MPU9250_ADDRESS,29,0x06);
  // Set gyroscope low pass filter at 5Hz
  I2CwriteByte(MPU9250_ADDRESS,26,0x06);
  // Configure gyroscope range
  I2CwriteByte(MPU9250_ADDRESS,27,GYRO_FULL_SCALE_1000_DPS);
  // Configure accelerometers range
  I2CwriteByte(MPU9250_ADDRESS,28,ACC_FULL_SCALE_4_G);
  // Set by pass mode for the magnetometers
  I2CwriteByte(MPU9250_ADDRESS,0x37,0x02);
  // Request continuous magnetometer measurements in 16 bits
  I2CwriteByte(MAG_ADDRESS,0x0A,0x16);
   pinMode(13, OUTPUT);
  Timer1.initialize(10000);         // initialize timer1, and set a 1/2 second period
  Timer1.attachInterrupt(callback);  // attaches callback() as a timer overflow interrupt
  // Store initial time
  ti=millis();
// Counter
long int cpt=0;
void callback()
  intFlag=true;
  digitalWrite(13, digitalRead(13) ^ 1);
// Main loop, read and display data
  while (!intFlag);
  intFlag=false;
  // Display time
  Serial.print (millis()-ti,DEC);
  Serial.print ("\t");
  // _______________
  // ::: Counter :::
  // Display data counter
//  Serial.print (cpt++,DEC);
//  Serial.print ("\t");
  // ____________________________________
  // :::  accelerometer and gyroscope :::
  // Read accelerometer and gyroscope
  uint8_t Buf[14];
  I2Cread(MPU9250_ADDRESS,0x3B,14,Buf);
  // Create 16 bits values from 8 bits data
  // Accelerometer
  int16_t ax=-(Buf[0]<<8 | Buf[1]);
  int16_t ay=-(Buf[2]<<8 | Buf[3]);
  int16_t az=Buf[4]<<8 | Buf[5];
  // Gyroscope
  int16_t gx=-(Buf[8]<<8 | Buf[9]);
  int16_t gy=-(Buf[10]<<8 | Buf[11]);
  int16_t gz=Buf[12]<<8 | Buf[13];
    // Display values
  // Accelerometer
  Serial.print (ax,DEC);
  Serial.print (ay,DEC);
  Serial.print (az,DEC);
  // Gyroscope
  Serial.print (gx,DEC);
  Serial.print (gy,DEC);
  Serial.print (gz,DEC);
  // :::  Magnetometer :::
  // Read register Status 1 and wait for the DRDY: Data Ready
  uint8_t ST1;
  do
    I2Cread(MAG_ADDRESS,0x02,1,&ST1);
  while (!(ST1&0x01));
  // Read magnetometer data
  uint8_t Mag[7];
  I2Cread(MAG_ADDRESS,0x03,7,Mag);
  // Magnetometer
  int16_t mx=-(Mag[3]<<8 | Mag[2]);
  int16_t my=-(Mag[1]<<8 | Mag[0]);
  int16_t mz=-(Mag[5]<<8 | Mag[4]);
  // Magnetometer
  Serial.print (mx+200,DEC);
  Serial.print (my-70,DEC);
  Serial.print (mz-700,DEC);
  // End of line
  Serial.println("");
//  delay(100);
I would look for better code.
You need to calibrate the magnetometer before you can calculate heading angles. The code you posted has calibration constants built in, which won't be correct for your device. These are the numbers in the statements below:
Once calibrated, the heading in radians can be calculated from the [u]horizontal[/u] components of the Earth's magnetic field:
float heading_in_radians = atan2(my, mx);
I'm looking for a better code too but I can't find anything
Try Google. Took me all of 30 seconds. https://www.google.com/search?q=arduino+mpu9250&ie=utf-8&oe=utf-8
These codes are too big
My word! What a dilemma.
I'm looking for a simple code that outputs accelerometer gyroscope and compass values like this one on top
After calculating radians with this tool
float heading_in_radians = atan2 (my, mx);
How I could calculate heading degrees?
2 pi radian equals 360 degrees. Dwight
Thanks for all replies also how I could calibrate the magnetometer with code on top? Thanks
