MPU data I2C inconsistency Leonardo/Duemilanove
I’m reading DMP info from a MPU6050 over I2C. Serial readback works fine on my Leonardo board, but seems scrambled or corrupt when the same program runs on a Duemilanove w/ 328p.
#include "I2Cdev.h"
#include "MPU6050_6Axis_MotionApps20.h"
#include "Wire.h"
// MPU control/status vars
MPU6050 mpu;
bool dmpReady = false;  // set true if DMP init was successful
uint8_t mpuIntStatus;   // holds actual interrupt status byte from MPU
uint8_t devStatus;      // return status after each device operation (0 = success, !0 = error)
uint16_t packetSize;    // expected DMP packet size (default is 42 bytes)
uint16_t fifoCount;     // count of all bytes currently in FIFO
uint8_t fifoBuffer[64]; // FIFO storage buffer
// orientation/motion vars
Quaternion q;           // [w, x, y, z]         quaternion container
VectorInt16 aa;         // [x, y, z]            accel sensor measurements
VectorInt16 aaReal;     // [x, y, z]            gravity-free accel sensor measurements
VectorInt16 aaWorld;    // [x, y, z]            world-frame accel sensor measurements
VectorFloat gravity;    // [x, y, z]            gravity vector
float ypr[3];           // [yaw, pitch, roll]   yaw/pitch/roll container and gravity vector
volatile bool mpuInterrupt = false;     // indicates whether MPU interrupt pin has gone high
void dmpDataReady() {
    mpuInterrupt = true;
    Wire.begin();
    TWBR = 24; // 400kHz I2C clock (200kHz if CPU is 8MHz)
    // initialize serial communication
    // initialize device
    mpu.initialize();
    // load and configure the DMP
    devStatus = mpu.dmpInitialize();
    // supply your own gyro offsets here, scaled for min sensitivity
    mpu.setXGyroOffset(220);
    mpu.setYGyroOffset(76);
    mpu.setZGyroOffset(-85);
    mpu.setZAccelOffset(1788); // 1688 factory default for my test chip
    // turn on the DMP, now that it's ready
    mpu.setDMPEnabled(true);
    // enable Arduino interrupt detection
    attachInterrupt(0, dmpDataReady, RISING);
    mpuIntStatus = mpu.getIntStatus();
    // set our DMP Ready flag so the main loop() function knows it's okay to use it
    Serial.println(F("DMP ready! Waiting for first interrupt..."));
    dmpReady = true;
    // get expected DMP packet size for later comparison
    packetSize = mpu.dmpGetFIFOPacketSize();
    // reset interrupt flag and get INT_STATUS byte
    // get current FIFO count
    fifoCount = mpu.getFIFOCount();
    // wait for correct available data length, should be a VERY short wait
    while (fifoCount < packetSize) fifoCount = mpu.getFIFOCount();
    // read a packet from FIFO
    mpu.getFIFOBytes(fifoBuffer, packetSize);
    // track FIFO count here in case there is > 1 packet available
    // (this lets us immediately read more without waiting for an interrupt)
    fifoCount -= packetSize;
    // display Euler angles in degrees
    mpu.dmpGetQuaternion(&q, fifoBuffer);
    mpu.dmpGetGravity(&gravity, &q);
    mpu.dmpGetYawPitchRoll(ypr, &q, &gravity);
    //prints data separated by commas
    Serial.flush();
    Serial.print(ypr[0] * 180/M_PI + 180);
    Serial.print(",");
    Serial.print(ypr[1] * 180/M_PI + 180);
    Serial.print(",");
    Serial.print(ypr[2] * 180/M_PI + 180);
    Serial.println("");
Any help?
Tell us more ! :stuck_out_tongue:
Which MPU-6050 module are you using, and how did you connect it ?
Do you have a MPU-6050 module with a power regulator for 3.3V on it ? If so, use the Arduino 5V to the Vcc of the module.
A Duemilanove with ATmeg328p is like the older Arduino Uno. The new Uno R3 version has a logic-port for the led at pin 13. But that has no influence on I2C.
The test sketch in the Playground checks for errors. Let it run for a few hours and see if the error is always zero.
http://playground.arduino.cc/Main/MPU-6050
