Hi all! This is probably the best area to post my question. Anybody here tried out and used the graphical 'MPU teapot' demo arduino code that works along side the software called 'Processing' that allows us to move the mpu6050 gyroscope/accelerator module board around, which makes the graphical '3D' teapot spin around in the graphical screen?
I notice that the demo does work. The teapot does indeed rotate when the IMU board is moved around. I do get some hiccups ...... intermittent freezing/lockup of the graphical teapot display. Once locked-up, it's usually necessary to shut-down the 'Processing' software, then disconnect and reconnect the UNO board's USB cable from the PC USB port (I'm using MEGA 2560), then start up the Processing software again. Everything will start working again ..... then after some time.... could be seconds.... could be minutes, or even 5 mins later....... freeze again.
Anybody experienced something similar to what I described? If so ..... did you manage to figure out how to sort out the intermittent freezing? Thanks for any recommendations about what I can try to cut down or even eliminate the freezes --- would be fantastic. In the meantime, I can scout around and see if I can spot anything that might offer some clues leading to the intermittent freeze.
