Mpu6050 and adafruit 6050 for ble mouse control
Hi , i am using a code that combines adafruit library as well as mpu6050. Mpu6050 helps me to get data to be used as ble mouse .
I am using adafruit library to get gyro x, y and z to plot as a curve on a graph .
So my experiemnet is to see my ble mouse as a graph(gyro X, gyro y and gyro Z) .
Unfortunately , i am not getting this curve although the adafruit library code would help me to get a graph independently when not use with mpu6050 ble code . Can you tell me the mistake ? I will attach my code and do let me know the line in the code which is wrong . I will screenshot of the curve too.
#include <Adafruit_MPU6050.h>
#include <Adafruit_Sensor.h>
#include <Wire.h>
Adafruit_MPU6050 mpu1;
#include <MPU6050.h>
#include <BleMouse.h>
#define MPU_ADDR 0x68
BleMouse bleMouse;
MPU6050 mpu;
int16_t ax, ay, az, gx, gy, gz;
int vx, vy;
int SDA_pin= 6;
int Scl_pin= 7;
int responseDelay = 10;
  pinMode(0,INPUT);
   pinMode(3,INPUT);
   pinMode(1,INPUT);
   pinMode(10,INPUT);
   Wire.setPins(SDA_pin ,Scl_pin);
    pinMode(SDA_pin,INPUT_PULLUP );
    pinMode(Scl_pin,INPUT_PULLUP );
      Wire.begin();
  bleMouse.begin();
  mpu.initialize();
  if (!mpu.testConnection()) {
    while (1);
  mpu1.setAccelerometerRange(MPU6050_RANGE_16_G);
  mpu1.setGyroRange(MPU6050_RANGE_250_DEG);
  mpu1.setFilterBandwidth(MPU6050_BAND_21_HZ);
  Serial.println("");
   delay(100);
  if(bleMouse.isConnected()) {
    Wire.write(0x3B);
    Wire.write(0x43);
    sensors_event_t a, g, temp;
  mpu1.getEvent(&a, &g, &temp);
  /* Print out the values */
Serial.print(g.gyro.x);
  Serial.print(",");
  Serial.print(g.gyro.y);
  Serial.print(",");
  Serial.print(g.gyro.z);
  Serial.println("");
  delay(10);
  mpu.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
  vx = -(gx + 260) / 150; // "-400" because the x axis of gyroscope give values about -350 while it's not moving. Change this value if you get something different using the TEST code, chacking if there are values far from zero.
  vy = (gz + 100) / 150; // same here about "-200"
  bleMouse.move(vx, vy);
  int a4=digitalRead(0);
  int b=digitalRead(3);
  int c=digitalRead(5);
  if(a4==1)
     bleMouse.click(MOUSE_LEFT);//10
     Serial.print("Clicked");
  if(b==1)
    bleMouse.click(MOUSE_RIGHT);//1
if(c==1)
  delay(20);
Your topic has been moved. Please do not post in "Uncategorized"; see the sticky topics in https://forum.arduino.cc/c/using-arduino/uncategorized/184.
so will people reply to my post in "project guidance" ?
Just to know dat
People usually reply to topics that they have some (or extensive) knowledge about.
i am asking you since you had moved the topic to "guidance" , will people share their thoughts in the guidance ?
Moderators do know what they do, and yes, this topic is the most common one for matters like Yours, lots of helpers.
