MPU6050 +Arduino
I am trying to read data from MPU6050 connected to the arduino using Python. I am able to read the data as normal in Arduino IDE with no issues, but when i use Python to read the data, the output is read. When i make changes to the sensor position, there is no changes in the reading for a while and post 40sec(approx.) of delay the changes are seen in the readings.
I also tried to change the baud rates and check but does not work.
Why have you started a new thread on the same topic?
I am sure it the same topic but a different issue. So, I thought its better to post a new topic
