MPU6050 connecting to digital LED strip not working, not even values
I bought a MPU6050 sensor for my Arduino Uno . I want to connect my digital LED strip to the MPU6050 sensor. I tried so many different websites for libraries. But so far nothing works. It's not the sensor itself if I wnat the simple code using the Arduino website he works. My question is whether you might be a geode library know that I can use to connect my MPU6050 a digital LED strip.
http://www.allaboutcircuits.com/projects/make-an-led-light-strip-ahrs-with-arduino-and-mpu-6050/ http://playground.arduino.cc/Main/MPU-6050
These are the websites I've used
at the first klomt not the library and the second is the base of arduino information .
PLZ help
You want to connect a LED strip directly to the MPU6050? Are you sure about that? Do understand what a sensor is?
Connect the MPU-6050 to the Arduino Uno. Remove everything else. Run the i2c_scanner : http://playground.arduino.cc/Main/I2cScanner Can the i2c_scanner detect the sensor ?
ieee488: You want to connect a LED strip directly to the MPU6050? Are you sure about that? Do understand what a sensor is?
I know what a sensor is, and I don't mean to connect the sensor directly to the LED strip. I just want to make a combination with the MPU 6050 and the digital led strip to the Arduino. Do you know how? If so can you tell me how to do this and help me :)?
ArduinRO: I know what a sensor is, and I don't mean to connect the sensor directly to the LED strip. I just want to make a combination with the MPU 6050 and the digital led strip to the Arduino. Do you know how? If so can you tell me how to do this and help me :)?
Seems like you need to crawl before you can walk, and the link provided above by Koepel would be a good start for you.
No one is going to provide code for you.
ieee488: Seems like you need to crawl before you can walk, and the link provided above by Koepel would be a good start for you.
Well the thing is i can all ready fly, don't know about you? I just don't know how to connect it to each other?
Koepel:
Thx
The link you posted had a connection diagram. Did you even look at it?
