So I am doing a project where I need to get acceleration data from an IMU. The catch is that it must read from a FIFO Buffer because the project I am doing will be computationally intensive and I can't loose readings while preforming those computations. So I tried the MPU6050 with FIFO via it's DMP. However, this requires an interrupt (and others that did it without one, theirs's always froze) and I can't be doing interrupts while doing my "computations".
Does anyone know a reliable way to get FIFO data from the MPU6050 without the use of an interrupt or know another alternative IMU that also has a FIFO buffer?
Hi, in the main project I will be using a Particle Boron based off of the nrf52840 (same cpu on arduino nano 33 ble). So that won't be an option. Thanks anyway.
