Im using the sensor MPU6050 to control movements of my robotic arm. The codes work fine when it is a standalone program but i keep encountering 'FIFO overflow' when the codes are complied into the main program. This is the code that i am using.
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#include "I2Cdev.h"
#include "MPU6050_6Axis_MotionApps20.h"
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
#include "Wire.h"
#endif
MPU6050 mpu;
RF24 radio(9, 8); // CE, CSN
const byte address[6] = "00001";
const int AccReadings = 10;
//Wrist Roll
int DataX[AccReadings];
int WRIndex = 0;
int WRtotal = 0;
int WRaverage = 0;
//Wrist Pitch
int DataY[AccReadings];
int WPIndex = 0;
int WPtotal = 0;
int WPaverage = 0;
//Shoulder Lift
int DataY2[AccReadings];
int SLIndex = 0;
int SLtotal = 0;
int SLaverage = 0;
//Elbow Lift
int ELaverage = 0;
//Arm Rotation
int ARaverage = 0;
float correct;
#define OUTPUT_READABLE_YAWPITCHROLL
#define INTERRUPT_PIN 2
bool blinkState = false;
// MPU control/status vars
bool dmpReady = false; // set true if DMP init was successful
uint8_t mpuIntStatus; // holds actual interrupt status byte from MPU
uint8_t devStatus; // return status after each device operation (0 = success, !0 = error)
uint16_t packetSize; // expected DMP packet size (default is 42 bytes)
uint16_t fifoCount; // count of all bytes currently in FIFO
uint8_t fifoBuffer[64]; // FIFO storage buffer
// orientation/motion vars
Quaternion q; // [w, x, y, z] quaternion container
VectorInt16 aa; // [x, y, z] accel sensor measurements
VectorInt16 aaReal; // [x, y, z] gravity-free accel sensor measurements
VectorInt16 aaWorld; // [x, y, z] world-frame accel sensor measurements
VectorFloat gravity; // [x, y, z] gravity vector
float euler[3]; // [psi, theta, phi] Euler angle container
float ypr[3]; // [yaw, pitch, roll] yaw/pitch/roll container and gravity vector
struct Sensor_Data
int WristRoll;
int WristPitch;
int ShoulderLift;
int ElbowLift;
int ArmRotation;
Sensor_Data data;
//Interrupt Detection
volatile bool mpuInterrupt = false;
void dmpDataReady()
mpuInterrupt = true;
radio.begin();
radio.openWritingPipe(address);
radio.setPALevel(RF24_PA_MIN);
radio.stopListening();
//Zero-fill Arrays
for (int i = 0; i < AccReadings; i++)
DataX[i] = 0;
for (int j = 0; j < AccReadings; j++)
DataY[j] = 0;
for (int k = 0; k < AccReadings; k++)
DataY2[k] = 0;
Wire.begin();
Wire.setClock(400000);
#elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
Fastwire::setup(400, true);
#endif
while (!Serial);
mpu.initialize();
pinMode(INTERRUPT_PIN, INPUT);
devStatus = mpu.dmpInitialize();
mpu.setXGyroOffset(49);
mpu.setYGyroOffset(-18);
mpu.setZGyroOffset(9);
mpu.setZAccelOffset(4427);
if (devStatus == 0)
mpu.setDMPEnabled(true);
attachInterrupt(digitalPinToInterrupt(INTERRUPT_PIN), dmpDataReady, RISING);
mpuIntStatus = mpu.getIntStatus();
dmpReady = true;
packetSize = mpu.dmpGetFIFOPacketSize();
// ERROR!
// 1 = initial memory load failed
// 2 = DMP configuration updates failed
// (if it's going to break, usually the code will be 1)
// Serial.print(F("DMP Initialization failed (code "));
//Serial.print(devStatus);
//Serial.println(F(")"));
/*smoothWR();
movementWR();
smoothWP();
movementWP();
smoothSL();
movementSL();*/
ElbowMovement();
radio.write(&data, sizeof(Sensor_Data));
void smoothWR()
WRtotal = WRtotal - DataX[WRIndex];
DataX[WRIndex] = analogRead(A0);
WRtotal = WRtotal + DataX[WRIndex];
WRIndex = WRIndex + 1;
if (WRIndex >= AccReadings)
WRIndex = 0;
WRaverage = WRtotal / AccReadings;
//Serial.println(WRaverage);
void movementWR()
WRaverage = map(WRaverage, 278, 419, 0, 180);
data.WristRoll = constrain(WRaverage, 0, 180);
//Serial.println(data.WristRoll);
void smoothWP()
WPtotal = WPtotal - DataY[WPIndex];
DataY[WPIndex] = analogRead(A1);
WPtotal = WPtotal + DataY[WPIndex];
WPIndex = WPIndex + 1;
if (WPIndex >= AccReadings)
WPIndex = 0;
WPaverage = WPtotal / AccReadings;
//Serial.println(WPaverage);
void movementWP()
WPaverage = map(WPaverage, 280, 421, 0 , 135);
data.WristPitch = constrain(WPaverage, 0, 135);
//Serial.println(data.WristPitch);
void smoothSL()
SLtotal = SLtotal - DataY2[SLIndex];
DataY2[SLIndex] = analogRead(A2);
SLtotal = SLtotal + DataY2[SLIndex];
SLIndex = SLIndex + 1;
if (SLIndex >= AccReadings)
SLIndex = 0;
SLaverage = SLtotal / AccReadings;
//Serial.println(SLaverage);
void movementSL()
SLaverage = map(SLaverage, 410, 270, 0 , 180);
data.ShoulderLift = constrain(SLaverage, 35, 180);
//Serial.println(data.ShoulderLift);
void ElbowMovement()
// if programming failed, don't try to do anything
if (!dmpReady) return;
// wait for MPU interrupt or extra packet(s) available
while (!mpuInterrupt && fifoCount < packetSize)
if (mpuInterrupt && fifoCount < packetSize)
// try to get out of the infinite loop
fifoCount = mpu.getFIFOCount();
// reset interrupt flag and get INT_STATUS byte
// get current FIFO count
// check for overflow (this should never happen unless our code is too inefficient)
if ((mpuIntStatus & _BV(MPU6050_INTERRUPT_FIFO_OFLOW_BIT)) || fifoCount >= 1024)
// reset so we can continue cleanly
mpu.resetFIFO();
Serial.println(F("FIFO overflow!"));
// otherwise, check for DMP data ready interrupt (this should happen frequently)
else if (mpuIntStatus & _BV(MPU6050_INTERRUPT_DMP_INT_BIT))
// wait for correct available data length, should be a VERY short wait
while (fifoCount < packetSize) fifoCount = mpu.getFIFOCount();
// read a packet from FIFO
mpu.getFIFOBytes(fifoBuffer, packetSize);
// track FIFO count here in case there is > 1 packet available
// (this lets us immediately read more without waiting for an interrupt)
fifoCount -= packetSize;
// Get Yaw, Pitch and Roll values
#ifdef OUTPUT_READABLE_YAWPITCHROLL
mpu.dmpGetQuaternion(&q, fifoBuffer);
mpu.dmpGetGravity(&gravity, &q);
mpu.dmpGetYawPitchRoll(ypr, &q, &gravity);
// Yaw, Pitch, Roll values - Radians to degrees
ypr[0] = ypr[0] * 180 / M_PI;
ypr[1] = ypr[1] * 180 / M_PI;
ypr[2] = ypr[2] * 180 / M_PI;
// Skip 300 readings (self-calibration process)
if (int l = 0; l <= 300) {
correct = ypr[0]; // Yaw starts at random value, so we capture last value after 300 readings
l++;
// After 300 readings
else {
ypr[0] = ypr[0] - correct; // Set the Yaw to 0 deg - subtract the last random Yaw value from the currrent value to make the Yaw 0 degrees
// Map the values of the MPU6050 sensor from -90 to 90 to values suatable for the servo control from 0 to 180
ELaverage = map(ypr[0], -90, 90, 0, 180);
data.ElbowLift = constrain(ELaverage, 30, 110);
ARaverage = map(ypr[1], -90, 90, 0, 180);
data.ArmRotation = constrain(ARaverage, 0, 180);
//Serial.println(data.ElbowLift);
Serial.println(ypr[1]);
#endif
Is there any ways to get rid of the FIFO overflow? Also When i tried to used Jeff Rowberg's example codes MPU6050_DMP6 the program will freeze after a few seconds. Is there any solution to that?
