MPU6050 Force Measurement Problem
Hello Guys !
I have a problem with my programm for my Arduino Mega. I want to measure the G-Force for acceleration moments in cars. My program is already ready to measure the force witch act on the car in standstill and acceleration torques.
When the car stands still without any movement it measures 0,95G that’s the Gravity and this is right.
But my problem is that the program has an error in his runtime because I can start it without any error message but after a certain time it stops. During the run it prints values to the Serial Monitor but after this certain time that stops too.
And to get the values again I need to restart the programm and that’s not in the way that I want it.
Guys could you help me please to get the programm run without this stop ?
Thank you very much !
#include "I2Cdev.h"
#include "MPU6050_6Axis_MotionApps20.h"
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
    #include "Wire.h"
#endif
MPU6050 mpu;
#define OUTPUT_READABLE_REALACCEL
#define LED_PIN 13  // (Arduino is 13, Teensy is 11, Teensy++ is 6)
bool blinkState = false;
bool dmpReady = false;
uint8_t mpuIntStatus;
uint8_t devStatus;
uint16_t packetSize;
uint16_t fifoCount;
uint8_t fifoBuffer[64];
Quaternion q;
VectorInt16 aa;
VectorInt16 aaReal;
VectorInt16 aaWorld;
VectorFloat gravity;
float euler[3];
float ypr[3];
uint8_t teapotPacket[14] = { '
, 0x02, 0,0, 0,0, 0,0, 0,0, 0x00, 0x00, '\r', '\n' };
volatile bool mpuInterrupt = false;
void dmpDataReady() {
    mpuInterrupt = true;
        Wire.begin();
        TWBR = 24;
    #elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
        Fastwire::setup(400, true);
    #endif
    while (!Serial);
    Serial.println(F("Initializing I2C devices..."));
    mpu.initialize();
Serial.println(F("Testing device connections..."));
    Serial.println(mpu.testConnection() ? F("MPU6050 connection successful") : F("MPU6050 connection failed"));
Serial.println(F("Initializing DMP..."));
    devStatus = mpu.dmpInitialize();
mpu.setXGyroOffset(220);
    mpu.setYGyroOffset(76);
    mpu.setZGyroOffset(-85);
    mpu.setZAccelOffset(1788);
    mpu.setFullScaleAccelRange(MPU6050_ACCEL_FS_16);
if (devStatus == 0) {
        Serial.println(F("Enabling DMP..."));
        mpu.setDMPEnabled(true);
Serial.println(F("Enabling interrupt detection (Arduino external interrupt 0)..."));
        attachInterrupt(0, dmpDataReady, RISING);
        mpuIntStatus = mpu.getIntStatus();
        Serial.println(F("DMP ready! Waiting for first interrupt..."));
        dmpReady = true;
        packetSize = mpu.dmpGetFIFOPacketSize();
        Serial.print(F("DMP Initialization failed (code "));
        Serial.print(devStatus);
        Serial.println(F(")"));
    pinMode(LED_PIN, OUTPUT);
  float x = mpu.getAccelerationX()/2048.0;
  float y = mpu.getAccelerationY()/2048.0;
  float z = mpu.getAccelerationZ()/2048.0;
  Serial.println(sqrt(xx+yy+z*z));
  delay(25);
